Results 1 to 10 of 18
Thread: Custom Polished Turbo Compressor wheel oil cap
    TN
    ***SOLD***
    Here is a custom oil cap that is guaranteed not to leak. The base is a modified OEM oil cap. I had to carefully remove material from the center to allow the oil cap to sit flush inside the cap. It also come with a NEW OEM oil cap gasket. The nut on the underside has been staked in, so no need to worry about it falling off. The screw has been counter-bored to sit flush.
    The turbo compressor wheel is a real MHI TD05 wheel. Brought it brand new and destroyed it by polishing it and grinding some material off the top. While it may sound easy, polishing a compressor wheel is almost as time consuming as a throttle body. And yes, it clears the hood.
    Price: $90 shipped within the USA. I know that sounds a little high, but the compressor wheel wasn't cheap, however my polishing labor is .
    damnit!!!!
    TN
    May have another one available before the end of year
    PM me details MISS!
    Feb 2011
    Scottsbluff, NE
    I want one too...
    1995 Dodge Stealth R/T Turbo
    Me too, me too!!!!
    Mar 2014
    me toooo!!!
    TN
    Anybody have some compressor wheels lying around, that are not too jacked up?
    Just using the 9B compressor?
    TN
    Actually the one pictured above is a TD05 16g wheel. I think the 9b wheel would look a little small, but I don't know as I've never seen one in person. Could you measure the exducer? If I could have found a cheap 9b wheel, that's what I probably would have used on my car, since I have stock turbos. But it might be more difficult to polish one LOL.
