Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Help!
  1. #31
    Nov 2014
    Ecu with a dead cylinder?
  2. #32
    No...
  3. #33
    Forum User supporter
    Lima, OH
    After reading through it sounds like he tried a compression test by hand and he checked the timing by only looking at the two front cams, so I thought maybe he isn't quite mechanically inclined yet, I said yet. I would hope the shop would have caught a cylinder with no compression, If not then I wouldn't take it back, But if they actually did a 60k and vss then I think they would have found something at 0 compression. But even if its not the issue its worth a look before you send it back. I know I have had four ecu's start showing signs of failure or failed after the cars had set for a year or more.
    :: Hers :: Pearl White '91 Dodge Stealth R/T TT ::
    :: His :: Black '92 Dodge Stealth R/T TT ::
    http://www.flickr.com/photos/51937543@N08/sets
  4. #34
    Another option is the age old intake washer dropped down the lower intake technique giving way to one cylinder with no compression. Check to see if the washers under the "nuts" on the ends of the upper intake are missing, or new please.
  5. #35
    Nov 2014
    Thanks for the confidence in my mechanical ability. I did a normal compression test on the front cylinders, and I was just trying to see if I could get anything out of the dead one by hand because I am working by myself and I can't be 2 places at once. I did get a very small reading by hand in the good ones. Only pulled the front timing cover, and the 2 front ones are set, where the problem is. I don't want to start taking too much apart and have the shop say I broke it.
    I will check for missing or new washers or nuts when I get a chance. It has been cold and I don't have a garage.
  6. #36
    Medford OR
    Car sits forever, someone who doesn't know any better runs it on bad gas, valve guides stick when it cools off, next time you start it, you bend valves. End of story... Time for a valve job.
  7. #37
    Nov 2014
    Hey guys. I've come up with some money to hopefully get the car fixed.
    Anyone have an idea the cost to pull the front head, and do the machine work? Worst case scenario. Only one cylinder doesn't have compression. They do all the machine work in house, so no taking the head to another shop.
  8. #38
    I would say 600-800 range.
  9. #39
    Nov 2014
    Thanks. I sure hope so.
