Yeah. I turned it over with a wrench and lined up the front ones with the marks. It was a shop that specializes in these cars that did the work, I'm just worried that I'm gonna be hit with a 2k bill when I've spent 3k on the car already.
0 compression on one cylinder tells the running rough story.
low blow huh?
I bought the car and it did not run, was sitting for a while. It was towed directly to the shop. A relay or something was unplugged. Shop got it running and it was smoking like crazy, so valve stem seals were done, along with the 60k service, said the belt didn't look good.
It was running pretty bad. Tried the compression test a couple times. Cranked it over by hand and the needle doesn't budge. If it had previously jumped wouldn't they be able to tell when they did the valve stem seals?
you can't do a compression test via hand, unsure if the needle will move on a new engine that way.
After I tested and got nothing I was trying to see if the needle would move if i turned it over by hand, as I am doing all of this by myself.
Have you ever done a leak down test? It will tell you what is leaking (intake or exhaust valves). Do a bit of research on leak down testing.
