Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Help!
    Nov 2014
    Help!
    Hey guys. I'm new here, so I apologize if this is a dumb question. I had valve seals re done in my 92 stealth tt along with 60k service. I drove it home from the shop, an hour of driving, and it ran like hammered crap. Did compression test on front 3 cylinders, and #5 has 0 compression. The timing is right on. Pulled the valve cover, and see nothing. Any ideas? I don't have a lot of money left to have this fixed. I'm afraid if it isn't the fault of the shop that did the work I'm screwed. Or they are gonna tell me it isn't their fault.
    Any input would be greatly appreciated.
    How did you check the timing? All 5 marks are on?
    Did it run like crap the entire time or suddenly began to run like crap?
    Nov 2014
    Only pulled the front cover and checked the front 2.
    Nov 2014
    It ran like crap when I first started driving home from the shop, but I attributed that to bad gas. It sat for a while. Seemed like it drove better after I filled the tank. But when I got into my area I stopped, and it wasn't running good.
    Eagle Lake
    Sounds like shops fault to me.
    Sounds like timing... You need to pull both timing covers, and the crank pully to check the timing.
    You also most likely will need a valve or two, so the heads will need to come off...
    Nov 2014
    Thanks guys. I guess I'm gonna have to bite the bullet and get it towed back to the shop.
    Some people mix up the timing marks also but you can't check it by looking at one mark anyway. You can look at the pulley and line up the mark on the timing cover then check the front and rear heads.
    Timing cover
    Timing marks on heads
