Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: Going single!
  1. #51
    Jan 2011
    Yep, that ^
    If you've got your +12v, ground and 5v reference voltage but the 5v doesn't pull down to 0v as the vane moves through the sensor then it's never going to go, new part or not.
  2. #52
    VR-3747 :D Not Verified
    Dayton Ohio
    That's what he's trying to get help with!! While I'm sure the compliments on the bay are appreciated, that's not what he's really after here. Everything he's looked at is what I would've recommended, so I don't have any input.
    Ah- I see. I thought he had gotten the fuel issue worked out, but hadn't heard a solution... thus my question!
    I agree with Chris though. I have also seen new parts not work correctly. I'll have to read it tomorrow and think about it a bit to see if I can come up with anything
  3. #53
    Oct 2014
    Awesome thanks guys. I honestly haven't spent too much time on it I was just seeing if anybody had an idea. Next step will be pulling the cog pulley off and bench testing the sensor. Kind of hard to find motivation when it's below 0 outside haha I need a bigger heater..
  4. #54
    Dayton Ohio
    Do you have the big CAS or the split crank angle sensor and cam angle sensor? If it's the split, check your cam angle sensor. I don't think anything else sends a signal to the ECU to tell the engine to fire injectors though. I am realizing how fricken rusty I am on these cars though... haven't done anything on them in like 2 years lol. Pitiful.
  5. #55
    Oct 2014
    I have a 95 so it's split. One crank and one cam sensor
  6. #56
    Oct 2014
    Upon inspecting every inch of the harness I found the pigtail for the coolant temp sensor was broken (that's going to be easy to find) but looked like it was making a connection still. Also the knock sensors wire was cracked open. Going to do my best to replace those, not sure if that could even have anything to do with my problem but I sure hope so
  7. #57
    Dayton Ohio
    Theres a relay inside on the passenger side of the center tunnel (not really a transmission tunnel). But that gets pressure to the fuel rail, which you confirmed. Which also confirms the pump, and yadda yadda yadda, so what sends a signal outside of the cam angle sensor on when to fire? It would have to be the cam angle sensor. Is your injector harness messed up maybe? Are you 100% sure the injectors aren't firing? ie, maybe you fouled plugs and it's not wanting to start? Just throwing out ideas. Hard to trouble shoot over the interwebz.
  8. #58
    Oct 2014
    New ecu coolant temp sensor and pigtail today and she started right up on the second crank... ugh
  9. #59
    Dayton Ohio
    The coolant temp sensor does have an effect on the fuel, but it should have been for warm up enrichment and that kind of stuff.
    Hmm? Glad you got it fixed. Time to make some vids
  10. #60
    Oct 2014
    I know that's why I was confused. But that's the only thing I messed with yesterday and it started right up. Oh well not complaining haha. I'll be breaking the engine in later today if the weather holds. Wish me luck!
