Results 1 to 10 of 23
Thread: 3 car part out plus garage clean-out Stock and Aftermarket
    Albany, OH
    Parting out 3 cars – 92 Stealth RT/TT, 98 3000GT SL and 93 3000GT base
    Note - Prices don’t include shipping, however I am somewhat flexible
    Note2 – This is just a partial list
    Aftermarket
    Dynamic Racing Stage 3 1g heads with new titanium components, new dual springs, new 99 lifters - $1200 These are N/A heads, but according to DR, they flow better than stock TT heads, but not quite as well as ported TT heads
    GT pro gt368sx turbos(need rebuilt) - $550
    Koyo Aluminum radiator x 2 $150 each
    2 - 5 point harnesses out of AWACS aircraft with harness bar -
    Interior
    Instrument cluster bezel - $20
    99 radio controls - $30
    Center vents - $15
    Rear wiper switch /blank plus bezel –
    -Charcoal(no broken tabs) $25
    -True black(no broken tabs) $35
    Mirror control/dimmer with bezel
    -Charcoal - $25
    -True black - $35
    Cruise switch - $10
    Fake pedal - $5
    Gas door/hatch levers trim
    -Charcoal $5
    -True black $10
    ECS/defrost switch - $10
    Fog light/headlight switch - $10
    Seat bolt covers
    -Charcoal - $5 ea or all 4 or $20
    -True black - $7.50 ea or all 4 for$25
    Airbags
    -1g $30
    -2g charcoal $35
    -2g True black - $40
    -98-99 - $50
    Coin holder/ cruise switch(appears painted black) - $15
    Lumbar adjust switch - $10
    Driver door window /lock switches - $20
    Heater/AC controls - $25
    Interior door handle bezel - $5
    Speedo/tach cluster
    -99 N/A - $35
    -93 RT/TT $40
    Steering column cover
    -Charcoal - $20
    -True black - $30
    aftermarket shift and e brake boots(black and tan) - $40/set
    map light - $10
    lower dash/ knee bolster
    -charcoal - $20
    -True black - $25
    Charcoal headliner - $100
    Charcoal sunvisors(non power) - $50
    rear most hatch plastic - $15
    Center console
    -Charcoal - $25
    -True black - $35
    96 up sunroof cover - $15
    Passenger side window motor(91-96)- $60
    Under hood
    upper timing covers(unsure of gen I think 1g) - $20 ea
    timing gears - $15 ea
    spark plug cover - $10
    MAF - $45
    N/A intake tube - $20
    Lower intake manifold - $25(have to check threads)
    TT intake plenum - $45
    Front O2 housing - $20
    Valve covers - $20 ea
    Wastegate actuators - $30 ea
    Power steering pump
    -V-belt - $30
    -Serpentine belt - $35
    Turbo coolant lines -$15 ea
    TT solenoid rack with solenoids - $30
    Slave cylinder - $15
    5 spd front diff without ring gear - $25
    Front exh manifold - $25
    Radiator 99 N/A 5 spd - $40
    TT engine mount(front) - $25
    Front engine mount – bracket(bolts to engine block) - $20
    Exterior
    Rear wiper motor - $25
    Sideskirt insert - $15
    2g rear bumpers(2 reds and 1 white) - $100 ea
    Moda R6 18x9 wheels - $400
    1997-1998 front bumper - $175
    94-98 headlights red( need clearcoat cleaned up) - $200
    Fenders(white and red) - $40
    Door shells(glass, but no motor)(red and white) $50
    2g hood(red) $100
    1g hood(white, black) - $60
    Stealth tail lights - $20 ea $35/set
    "I never knew I could drive like that. I was going faster than I've ever gone before, and yet, it all seemed to be happening in slow motion. I was seeing three and four moves ahead, weaving in and out of lanes like an Olympic skier on a gold medal run. I knew I was challenging the very laws of physics."
    White drivers fender and door? And pics/condition please.
    The Panda Not Verified
    Washougal WA/Portland OR
    How much for carpet?
    Albany, OH
    The Stealth has both, however, it has been repainted and is a different shade of white. I have a white N/A RT as well and they are noticeably different.
    Albany, OH
    Quote Originally Posted by vr4tune View Post
    What color are you looking for?
    Shipped to 98629 for fender and door. Maybe just fender.
    STL, MO
    2 gen stealth rear bumper?
    What shape are the wheels in? Pics?
    1991 Stealth RT/TT
    Albany, OH
    I'd have to check, but I'm really not keen on shipping larger items. The only reasonably priced method is Greyhound and I don't have a station near me. Might be able to do the fender easy enough. Let me check.
    As always, here is what I am interested in.
    1st gen tt harness (entire car)
    PS Rack
    Let me know if you are even interested.
    Albany, OH
    PS Rack
    The only 1g TT car I have is a Stealth and it wouldn't have the Active Aero stuff on it. Not sure if there are any other differences between 3kgt and Stealth harnesses or not
