1991 $ 6,500
For Sale:
1991 3000GT VR-4.
80,xxxx miles on the car. The car runs great and is able to be driven at this point. Only selling this as my living situation is changing rapidly on me.
What's good about the car:
Decent Interior, only needs a little work to be great (Replace the seats covers and drivers side a-pillar cover). Recently replaced dash vents (No Cracks, woohoo).
* Replaced Shift Boot / Shifter
* Replaced Head Unit
* Replaced Ebrake cover
* Replaced Dash (With another used, but better)
* Defi Racer Gauges in stock center cluster (Boost, Water Temp, Oil Pressure)
* New Drivers side Window Regulator
Car runs and drives great, took it for an 8 hour road trip. Ran well both ways with no issues.
* New tires
* New front tie rod ends
* New front ball joints
* 13G Turbos - Currently running 11 PSI
* New Tires - Maybe 3K miles on them
* Replaced Fuel Pump - Walbro 255
* Rebuilt Transmission & Transfer Case - 2013 Jacks Transmissions
* Replaced Clutch - 2012
* Larger (Unknown brand) side mounts
* Recentish Alignment (Spring of 2014)
* Older HKS Exhaust (From Cat-back)
* EGR Block off
What the car needs:
* 60K done (Previous owner claimed it was done at 45k. Needs to be done yet)
* Has one weird issue where it seems the car loses fuel pressure when off so it takes longer to start
* Runs slightly rich - Possibly a leak in the throttle body
* Paint is in OK shape at best, pealing clear coat on the spoiler, had to reapply clear coat for it.. looks a bit funky
* Few small dents and scratches around the car.
A large portion of the work was done by Submlie_iswhatIgo
Looking to get 7K OBO.
PM if interested. Will post any other requested pictures.
