Results 1 to 7 of 7
Thread: Catalytic convertor different between years?
    Hitokiri Battousai verified
    June 2002
    in the desert
    Having a serious brain fart and can't remember if there is any real differences. I need one so I can pass emissions and found someone selling from a 93. I have a 95 (though I think I have 1st gen exhaust bits, it's hard to remember any longer to be honest).
    So help me out here - beyond the extra O2 bungs, is there any real difference between years of exhaust and specifically the cat?
    I lack color... verified
    Aug 1998
    The rear pre-cat is different between the 1G and 2G cars. Its turned more on the 2G cars for the larger t-case.
    TN
    If you are talking about the main cat, they are all the same from cars made 6/1/1992 - 1999.
    Quote Originally Posted by dbest671 View Post
    I bet asa says that the part # is the same, but I wonder if the used ones are the same. OBDII cats are usually different.
    TN
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    I always wondered the same thing. FWIW, when I had a used OBD-II main [from a forum member] swapped into a friend's '93 VR-4, it ended up sitting slightly angled. Talk about weird. I was always aware of the rear pre-cat/DP, but this was different.
    If you have a 95, you dont need the OBDII, plus the OBD1 should be significally cheaper. 96+ requires the OBDII.
