I have a 93 RT TT (formerly HellBringer's and WAYNECAR) and have had an issue that has had me scratching my head for sometime. The car seems to go dead after sitting a day or so. I have replaced the battery with a brand new one, that was tested / load tested from where I bought it and it will hold a charge outside the car for days on end. However, as soon as you install her...shes starts dropping in voltage metered at the posts via multimeter.
At times, I will start with 12.81v and after a few hours it will drop down to 12.60v and continue to plummet. You can literally watch the multimeter dither between current voltage by 0.01v, until it drops a bit and continues to dither on southward (again by 0.01v at a time).
Hopefully I wont jump back and forth too much to add to the confusion, but I am really stumped.
Now I went to do a parasitic draw test on the car (which I think I did correctly) and didn't see any obvious signs of draw. I placed the multimeter in series with the negative ground cable and the negative battery post (meter dial set to 20/10A measuring under DC mA and connected the leads to the appropriate spots on the meter {COM / 10A } and saw a draw of 0.04. Is the 0.04 something to be concerned with?
With a steady reading of 0.04, I began pulling each fuse and did not see a significant drop...it stayed for the most part at 0.04 but would dither to 0.03.
With that portion complete, I though maybe the alternator was causing the drain since I read that it could feed back power from the battery. I took the meter out of series and just stated checking voltage again. Within that time I went down appox. 0.05 v which was probably half an hour or so. Again, the voltage would dither back and forth 0.01v at a time and continue south.
I pulled both the harness clip and power wire to the alternator free and still see the meter dithering south, so I guess I could say the alternator is not my issue and is good (this too was tested at time of battery load testing).
Needless to say, I will bet if I leave the car as is (everything hooked up as it should be) she will be deader than a door nail by this time tomorrow.
The car does have an aftermarket stereo and amps, however I have it defeated by pulling the Stinger fuse off the firewall where its mounted.
Can anyone offer some insight on where to turn to next?
