Well I ended up getting the retaining ring out and removing the shaft assembly, only to find out that the seal that came with the rebuild kit is too small and does not fit. So I reinstalled the shaft and pulley assembly using the original seal underneath that bearing, hoping that will not leak. At least until I pull the engine again, and then just buy a new pump.
On to the other issue I ran into, the little spacer in the terminal assembly has broken into several pieces. Would cherry hill have any of these parts available? If not maybe I can grab one from a part out or if someone has a spare.
