Are you able to get the clearance like shown in this pic?
If your snap ring pliers won't fit in between then you can try an impact driver to turn the lock nut. I had a Type A so I didn't have to fight that issue.
Are you able to see my pics posted on the first page? Also, lock nut?
Sorry is there no locknut outside the pulley? Can't remember. Why can't you push the shaft through?
No there is no lock nut that I know of lol. Well I tried putting the housing in a vice and taping/hitting the end of the shaft as to expose the bearing a little like the picture you showed. It wouldn't come out any and I was hitting it decently hard.
Have you disassembled the terminal section? It might interlock some how.
This is how far I have it broken down. Removed the terminal assembly and the flow control valve. Once again tried putting it in the vice and hitting it out but it won't budge.
I hate banging on stuff like this. Can you try using the vise to press out the shaft? You might try a PM to Toni on this site and point him to this thread. He wrote that guide on 3si.
I sent Toni a PM so maybe he can chime in. I tried configuring the pump in the vice to press out the shaft but I dont know if it's possible.
There are two versions of power steering pump design. In the one you have, and what I pictured is one with a pressed on bearing onto the shaft held in by the snap ring. you can't get the shaft out without removing that ring.
2013 January Car of the Month - All 3s
2011 November Car of the Month - Interior
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
Uncut 3000GT keys for sale! Various colors!
This is what the beaing/shaft combo look like.
