Results 1 to 10 of 21
Thread: Nuts & Bolts reference thread
    I recently had all of my fasteners re-plated in one batch so I put together this list of every fastener on my car, and took a picture of all of the fasteners that go on each assembly. A couple of members have asked for me to share this stuff so I will do that in this thread. I want to eventually put everything up on a website with a easier to use interface, but that will take some time, so this thread will serve as a place holder for that. This information may or not be helpful for just general work on your car. It was made so I could put the right bolts in the right baggies after plating. It doesn't necessarily tell you where every bolt goes, but it will get you close.
    The list is 99% complete and about 95% accurate. Since going through my fasteners, I have found a couple of irregularities in the notes but overall, almost all of them are accurate. Not everything is written with its official term, remember, I just wrote this so I would understand it. And my methods did change a little bit throughout the process so it is not entirely consistent.
    How to use this thread
    There are 4 main categories:
    Underbody: Includes everything under the car
    Engine: Everything in the engine bay including the engine
    Interior: Everything in the interior of the car
    Exterior: Everything that bolts to the outside of the car
    A few sets of bolts got put into the wrong category, so if you are looking for a certain part and see it in the list, but not in the photo album, then it may have accidentally been put in another album. Sorry, it is only a few. If you plan on really using this list frequently, I recommend downloading all of the photobucket albums on your computer since photobucket is slow to use. I also would save each list into a notepad document. Its up to you. To find your part on the list, try a search, hit CTRL + F on your keyboard and type in your part to see if it comes up. Try a couple terms if it does not come up immediately, I don't know the exact name of every part on the car, I wrote it so I would understand it.
    Below is an example of 1 set of bolts for the water pump. There are corresponding pictures of each bolt laid out to go with this list and they are hosted on photobucket(which I don't like but its the only place I can host the 1000+ pictures). If it is the 5th set of bolts on the list, then it should be the 5th row of bolts in the picture of that set.
    Example:
    WATER PUMP: DONE!!
    4 BOLTS - FLANGE - G7 - 12MM - 33.33MM LONG X 16.05M WIDE - CLEAR 4
    How to read it:
    4 bolts - means there are 4 identical bolts
    Flange - it means there is a flange on the head of the bolt
    G7 - it means grade 7 or a "7" on the head of the bolt, some will be symbols which I tried to type out
    12mm - it is a 12mm bolt, a 12mm socket will fit on it
    33.33mm long - this is the length of the bolt in mm taken with a digital caliper
    16.05mm wide - this is the widest point on the bolt, if the bolt has captive washers, then it is the width of the biggest washer.
    Clear - it means nothing, I plated my bolts with a clear(silver) finish and a black finish so this was so I would know what color to look for.
    Not in this example:
    CLW- It means a captive lock washer is installed on the bolt
    CW- It means a captive washer is installed on the bolt
    CW/LW- It means there is both a captive washer and lock washer installed on the bolt.
    PS - It means either passenger side or power steering.
    Ds- Driver side
    Phillips - It means it is a Phillips head, some bolts even though they may be 10mm hex head, also have an indent for a phillips head screwdriver.
    Screw or Bolt - This is where I wasn't consistent, but if it has a pointy end, I called it a screw, it it has a flat end, I called it a bolt. I called all of the "machine screws" bolts even though they do not have a hex head.
    "Done!!" - Means nothing, this just means that I have found every fastener in the set and put them back in its baggy. You will see "missing" on some, ignore that too. That just means I haven't sorted it out yet.
    "May be wrong" - This is important, my car did not have 100% correct bolts when I started it, so this was a reminder to myself to look into ASA to see what type of bolt should be there. It is an indicator that the correct bolt is probably not listed for the part.
    If you have any questions about anything, feel free to ask. Hopefully this is helpful.
    Learn how to Powder Coat at www.powdercoatguide.com.
  2. The Following 4 Users Say Thank You to 99ishVR-4 For This Useful Post:
  3. #2
    Engine Bay
    Engine Bay photobucket album: Mitsubishi 3000gt Nuts And Bolts - Engine Bay Photos by mudvaynedude122 | Photobucket
    PS HEADLIGHT BUCKET - FUSEBOX(2) - OVERFLOW BOTTLE(1) DONE!!
    1 BOLT - CW/LW - G4 - 12MM - 22MM LONG X 18MM WIDE - CLEAR
    2 BOLTS - CW/LW - G4 - 10MM - 24MM LONG X 13MM WIDE - CLEAR
    AC COMPRESSOR: DONE!!
    4 BOLTS - CW/LW - G7 - 12MM - 101MM LONG X 18MM WIDE - CLEAR (BAKE)
    TRANSMISSION: DONE!!
    1 FLANGE BOLT - G7 - 17MM - 65MM LONG X 29MM WIDE - CLEAR (BAKE)
    2 BOLTS - CLW - G7 - 17MM - 37MM LONG X 22MM WIDE - CLEAR (BAKE)
    2 BOLTS - CLW - G(/O) - 17MM - 48MM LONG X 21MM WIDE - CLEAR (BAKE)
    1 BOLT - CLW - G(/O) - 17MM - 44MM LONG X 21MM WIDE - CLEAR (BAKE)
    FRONT TRANSMISSION STAY: DONE!!
    2 BOLTS - CLW - G7 - 14MM - 35MM LONG X 17MM WIDE - CLEAR (BAKE)
    REAR TRANSMISSION STAY: DONE!!
    2 BOLTS - CLW - G10 - 32MM LONG X 18MM WIDE - CLEAR (BAKE)
    WIPER MOTOR(EXTRAS)
    2 BOLTS - CW/LW G4 - 10MM - 34MM LONG X 18MM WIDE - CLEAR
    1 LOCK WASHER - 20MM WIDE - CLEAR
    CLUTCH LINE BRACKET: DONE!!
    2 NUTS - SPINNING FLANGE - 12MM - 18MM WIDE X 8MM DEEP - CLEAR
    THROTTLE BODY: DONE
    4 BOLTS - CLW - G4 - 10MM - 60MM LONG X 19MM WIDE - CLEAR
    IC PIPE (PLENUM): DONE!!
    1 BOLT - CLW - G4 - 12MM - 20MM LONG X 15MM WIDE - CLEAR
    THROTTLE CABLE BRACKET (PLENUM): DONE!!
    2 BOLTS - CW/LW - G4 - 10MM - 20MM LONG X 18MM WIDE - CLEAR
    UPPER PLENUM: DONE!!
    2 BOLTS - CLW - G7 - 12MM - 90MM LONG X 20MM WIDE - CLEAR (BAKE)
    3 BOLTS - CLW - G7 - 12MM 50MM LONG X 20MM WIDE - CLEAR (BAKE)
    2 FLANGE NUTS - 12MM - 17MM WIDE X 9MM DEEP (BAKE)
    2 LOCK WASHERS - 15.07MM WIDE X 8.39MM HOLE X 2.11MM THICK - CLEAR
    CLUTCH MASTER CYLINDER: DONE!!
    AC DRIER LINES: DONE!!
    2 BOLTS - CW/LW - G4 - 10MM - 29MM LONG X 18MM WIDE - CLEAR MAY BE THE WRONG SIZE WASHER
    AC LINE-FIREWALL: DONE!!
    1 BOLT - CW/LW - G7 - 10MM - 34MM LONG X 12MM WIDE - CLEAR
    1 BOLT - CLW - G4 - 12MM - 21MM LONG X 15MM WIDE - CLEAR
    1 NUT - SPINNING FLANGE - 12MM - 18MM WIDE X 8MM DEEP - CLEAR
    RADIATOR FANDS (INCOMPLETE) - DONE
    4 BOLTS - 10MM/PHILLIPS - CW/LW - 20MM LONG X 15MM WIDE - CLEAR
    2 BOLTS - G4 - 10MM - CW/LW - 20MM LONG X 15MM WIDE - CLEAR
    FIREWALL - BIG LIST: DONE!!
    1 BOLT - CLW - G4 - 12MM - 40MM LONG X 14MM WIDE - CLEAR + 1 EXTRA
    6 BOLTS - G4 - 12MM - CLW - 20MM LONG X 14MM WIDE - CLEAR
    4 BOLTS - CW/LW - G4 - 10MM - 20MM LONG X 13MM WIDE - CLEAR
    INTERMEDIATE SHAFT: DONE!!
    2 BOLTS - G(+O) - 14MM - 31MM LONG X 17MM WIDE - CLEAR (BAKE)
    2 LOCK WASHERS - 18MM WIDE - CLEAR
    DS SUBFRAME: DONE!!
    2 BOTLS - CW/LW - G10 - 14MM - 52MM LONG X 23MM WIDE - CLEAR (BAKE)
    4 BOLTS - CW/LW - G10 - 14MM - 32MM LONG X 23MM WIDE - CLEAR (BAKE)(adjusted to correct bolts)
    PS SUBFRAME: DONE!!
    2 BOLTS - CW/LW - G10 - 14MM - 52MM LONG X 23MM WIDE - CLEAR (BAKE)
    6 BOLTS - CW/LW - G10 - 14MM - 23MM LONG X 23MM WIDE - CLEAR (BAKE) (adjusted to correct bolts)
    ABS LINE - FIREWALL BRACKETS - UNEEDED?:
    1 BOLT - CLW - G4 - 12MM - 19MM LONG X 15MM WIDE - CLEAR
    TRANSFER CASE:
    3 FLANGE BOLTS - G DORN 8.8 - 17MM - 135MM LONG X 26MM WIDE - CLEAR (BAKE)
    2 FLANGE BOLTS - G DORN 8.8 - 17MM - 72MM LONG X 26MM WIDE - CLEAR (BAKE) (adjusted to 2)
    ACC PULLEY TENSIONER BOLT: DONE!!
    1 BOLT - CLW - G7 - 12MM - 106MM LONG X 15MM WIDE - CLEAR (BAKE)
    1 BOLT - CW/LW - G7 - 14MM - 58MM LONG X 23MM WIDE - CLEAR (BAKE)
    FUEL RAILS: DONE!!
    4 BOLTS - CLW - G4 - 12MM - 46MM LONG X 15MM WIDE - CLEAR
    8 BOLTS - CLW - G7 - 10MM - 19MM LONG X 17MM WIDE - CLEAR (BAKE)
    6 INJECTOR CLIPS (CLEAR)
    DS HEADLIGHT BUCKET - INTERCOOLER PIPE DONE!!
    1 BOLT - CLW - G4 - 12MM - 20MM LONG X 10MM WIDE - CLEAR
    SHIFTER CABLES: DONE!!
    1 BOLT - CLW - G7 - 12MM - 25MM LONG X 15MM WIDE - CLEAR
    1 BOLT - CLW - G4 - 12MM - 22MM LONG X 15MM WIDE - CLEAR (REPLACE)(PROBABLY WRONG)
    2 BRAKE LINE CLIPS - CLEAR
    BRAKE LINES FROM MC: DONE!!
    4 CLIPS - CLEAR
    ALTERNATOR: DONE!!!!
    1 BOLT - SQUARE HEAD - 106MM LONG X 12MM WIDE - CLEAR
    4 BOLTS - CW- 8MM - 66MM LONG X 13MM WIDE - PHILLIPS - CLEAR
    1 FLANGE BOLT - G7 - 12MM - 39MM LONG X 18MM WIDE - CLEAR (BAKE)
    1 NUT - FOR PULLEY - 25MM LONG X 5MM DEEP - CLEAR (BAKE)
    1 LOCK WASHER - 30MM WIDE - CLEAR (BAKE)
    1 NUT - SPINNING FLANGE - 12MM - 15MM WIDE X 7MM DEEP - CLEAR
    1 LOCK WASHER - 16MM WIDE - CLEAR
    1 NUT - 12MM - 12MM WIDE X 6MM DEEP - CLEAR
    1 WASHER - 18MM WIDE - CLEAR
    CLUTCH LINE: DONE!!
    2 CLIPS - 26MM WIDE X 27MM TALL - CLEAR
    WIPER MOTOR: DONE!!!
    1 BOLT - CW/LW+SLEEVE - 10MM - 31MM LONG X 15MM WIDE - CLEAR
    3 BOLTS - CW+SLEEVE - 10MM - 27MM LONG X 17MM WIDE - CLEAR
    1 WASHER - 17MM WIDE - CLEAR (CURRENTLY NO WASHER INSTALLED - CANT FIND - LOOK FOR WASHER 17.65W X 6.12HOLE X 1.51 THICK
    1 NUT - 12MM - 13MM WIDE X 4MM DEEP - CLEAR
    3 SCREW BOLTS - 12MM LONG X 6MM WIDE - PHILLIPS - CLEAR
    2 SCREW BOLT - CW / 10MM LONG X 8MM WIDE - PHILLIPS - CLEAR
    1 BRACKET - MOTOR ARM
    PS RESEVIOR: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 20MM LONG X 14MM WIDE - CLEAR
    2 HOSE SPRING CLAMPS - 20MM WIDE X 12MM DEEP - CLEAR
    1 SPRING - 21MM LONG X 12MM DEEP - CLEAR
    1 RESERVIOR CAP - CLEAR
    RADIATOR BRACKETS: DONE!!
    4 BOLTS - CW/LW - G4 - 12MM - 25MM LONG X 17MM WIDE - CLEAR
    HOOD LATCH: DONE!!
    3 BOLTS - CW/LW - G7 - 10MM - 20MM LONG X 13MM WIDE - CLEAR 2 ON CAR
    1 LONG SPRING - 70MM LONG X 8MM WIDE - CLEAR ON CAR
    1 SHORT FAT SPRING - 55MM LONG X 17MM WIDE - CLEAR ON CAR
    PS RESERVIOR BRACKET - ENGINE BAY SIDE: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 19MM LONG X 14MM WIDE - CLEAR
    BIGGEST AC LINE: DONE!!
    2 BOLTS - CW/LW - G4 - 10MM - 34MM LONG X 18MM WIDE - CLEAR
    3 NUTS - SPINNING WASHER - 12MM - 18MM WIDE X 8MM DEEP - CLEAR
    2 NUTS - SPINNING WASHER - 10MM - 14MM WIDE X 6MM DEEP - CLEAR
    3 BUSHING INSERTS - 20MM WIDE X 13MM TALL - CLEAR
    AC FUSEBOX: DONE!!
    2 BOLTS - CW/LW - G4 - 12MM - 30MM LONG X 20MM WIDE - CLEAR
    SRS SENSORS: DONE!!
    BRAKE BOOSTER: DONE?
    4 NUTS - SPINNING FLANGE - 12MM - 18MM WIDE X 8MM DEEP - CLEAR
    2 NUTS - 12MM - 12MM WIDE X 6MM DEEP - CLEAR
    1 NUT - LOCKING FLANGE - 14MM - 19MM WIDE X 9MM DEEP - CLEAR
    2 LOCK WASHERS - 15MM WIDE - CLEAR
    1 CLEVIS - 38MM LONG X 22MM WIDE - CLEAR
    1 CLIP PIN - 30MM LONG X 13MM WIDE - CLEAR
    1 PIN - 25MM LONG X 10MM WIDE - CLEAR
    FUEL FILTER ASSEMBLY: DONE!!
    2 BANJO BOLTS - G7 - 19MM - 30MM LONG X 19MM WIDE - CLEAR
    2 BOLTS - CW/LW - G4 - 12MM - 30MM LONG X 21MM WIDE - CLEAR
    1 BOLT - CLW - 10MM - 59MM LONG X 1MM WIDE
    1 BOLT - CLW - G4 - 12MM - 19MM LONG X 14MM WIDE
    FUEL LINE FROM FILTER TO RAIL
    1 FUEL LINE - CLEAR
    AC CONDENSER: DONE!!
    2 BOLTS - CW/LW - G7 - 12MM - 35MM LONG X 17MM WIDE - CLEAR
    2 BOLTS CW/LW - 10MM - 29MM LONG X 12MM WIDE - PHILLIPS - CLEAR
    1 STUD - 48MM LONG X 8MM WIDE - CLEAR
    1 STUD - 38MM LONG X 6MM WIDE - CLEAR
    1 SCREW BOLT - 14MM LONG X 10MM WIDE - PHILLIPS - CLEAR
    1 NUT - SPINNING FLANGE - 10MM - 14MM WIDE X 6MM DEEP - CLEAR
    2 WASHERS - 35MM WIDE - 7MM WIDE HOLE - 1MM THICK - CLEAR
    2 BUSHING INSERTS - 22MM WIDE X 12MM TALL - CLEAR
    2 SLEEVES - 10MM LONG X 9MM THICK - 7MM HOLE - CLEAR
    BRAKE PROP VALVE: ADDED TO FIREWALL:LONGLIST BAG DONE
    FRONT PS BRAKE LINE BRACKETS - NOT 100% DONE!!
    FRONT PS FRAME RAIL - TOP DONE!!
    2 BOLTS - CW/LW - G4 - 12MM - 26MM LONG X 18MM WIDE - CLEAR
    1 BOLT - CLW - G4 - 12MM - 21MM LONG X 14MM WIDE - CLEAR
    CHARCOAL CANISTER LINE - PS FRAME RAIL NEAR FIREWALL: DONE!!
    1 BOLT - CLW - G4 - 12MM - 19MM LONG X 14MM WIDE - CLEAR
    UPPER FIREWALL: DONE!!
    1 BOLT - CW/LW - G4 - 12MM - 25MM LONG X 18MM WIDE - CLEAR
    1 BOLT - CW/LW - G "E" - 12MM - 21MM LONG X 18MM WIDE - CLEAR
    1 BOLT - CLW - G4 - 12MM - 20MM LONG X 14MM WIDE - CLEAR
    1 BOLT - CW/LW - G4 - 10MM - 20MM LONG X 13MM WIDE - CLEAR
    1 BOLT - SLIGHT FLANGE - G7 - 10MM - 20MM LONG X 13MM WIDE - CLEAR
    1 BOLT - SLIGHT FLANGE - G7 - 10MM - 16MM LONG X 13MM WIDE - CLEAR
    PS FRAME RAIL - SIDE: DONE!!
    5 BOLTS - CW/LW - G4 - 12MM - 25MM LONG X 18MM WIDE - CLEAR
    DS FRAME RAIL & STRUT TOWER: DONE!!
    1 BOLT - CW/LW - G4 - 12MM - 26MM LONG X 18MM WIDE - CLEAR
    2 BOLTS - CLW - G4 - 12MM 21MM LONG X 14MM WIDE - CLEAR
    LOWER FIREWALL: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 22MM LONG X 14MM WIDE - CLEAR
    CLUTCH MASTER CYLINDER: DONE!!!!
    1 BOLT/PIN - FLAT HEAD - 31MM LONG X 10MM WIDE - CLEAR
    1 NUT - 12MM - 12MM WIDE X 5MM DEEP - CLEAR
    1 HOSE CLAMP BOLT - 10MM - 35MM LONG X 20MM WIDE X 11MM DEEP - CLEAR
    1 HOSE CLAP BOLT WASHER - 10.5MM WIDE X 4.35MM HOLE X 2.05MM THICK - CLEAR
    1 CLEVIS - 43MM LONG X 22MM WIDE X 19MM DEEP - CLEAR
    1 PULL COTTER PIN - 30MM LONG X 13MM WIDE - CLEAR
    1 HOSE CLAMP - 36MM WIDE X 1MM DEEP - CLEAR
    1 PIN - 25MM LONG X 14MM WIDE - CLEAR
    BRAKE MASTER CYLINDER: DONE!!
    1 BOLT/PIN - 44MM LONG X 12.6MM WIDE - PHILLIPS - CLEAR
    1 BOLT/PIN - 37MM LONG X 10MM WIDE - PHILLIPS - CLEAR
    SHORT FAT AC LINE BRACKET: DONE!!
    1 BOLT - CW/LW - G4 - 10MM - 16MM LONG X 13MM WIDE - CLEAR
    HOOT LATCH 2 - (ADD TO HOOD LATCH 1 BAG) DONE!!
    1 BOLT - CW/LW - G4 - 10MM - 29MM LONG X 18MM WIDE - CLEAR (TRY TO USE IN PLACE OF BOLT BELOW)
    1 BOLT - 10MM - G(NB/4.3) - 29MM LONG X 10MM WIDE - CLEAR
    1 WASHER - 17.82MM WIDE X 8.58MM HOLE X 1.53MM THICK - CLEAR (ONLY USE IF 1ST BOLT DOES NOT WORK)
    SPRING - 17.26MM TALL X 47.73MM WIDE - CLEAR
  4. #3
    Engine Bay cont.
    RADIATOR FANS: DONE!!
    3 BOLTS - CW/LW PHILLIPS - 8MM - 16MM LONG X 18MM WIDE - CLEAR
    1 BOLT - CW/LW - PHILLIPS - 10MM - 20MM LONG X 16MM WIDE - CLEAR
    3 BOLT/SCREWS - PHILLIPS - FLANGE HEAD - 14MM LONG X 10MM WIDE - CLEAR
    1 NUT - SPINNING FLANGE - 8MM - 12MM WIDE X 5MM DEEP - CLEAR
    1 NUT - FLANGGE - 8MM - 15MM WIDE X 6MM DEEP - CLEAR
    POWER STEERING PUMP:
    4 BOLTS - CLW - G7 - 12MM - 32.98MM LONG X 13.43MM WIDE - CLEAR
    2 BOTLS - CLW - G7 - 10MM - 15.95MM LONG X 1.56MM WIDE - CLEAR
    1 NUT - 17MM - 16.94MM WIDE X 6.91MM DEEP - CLEAR
    1 LOCK WASHER - 21.11MM WIDE X 3.18MM DEEP X 12.4MM HOLE - CLEAR
    POWER STEERING PUMP SENSOR(IN SAME BAG):
    1 FITTING - 19MM - 13.04MM LONG X 18.94MM WIDE - CLEAR
    1 WASHER - 7.89MM WIDE X .79MM DEEP X 4.44MM HOLE - CLEAR
    1 CLIP - 6.99MM WIDE X .60MM DEEP - CLEAR CANT FIND
    STARTER: DONE!!!
    2 BOLTS - FLANGE HEAD - 8MM - 130MM LONG X 10.19MM WIDE - CLEAR
    2 BOLTS - FLANGE HEAD - G7 - 14MM - 64.22MM LONG X 18.82MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 26.39MM LONG X 11.84MM WIDE - CLEAR --- REPLACE
    2 SCREWS - PHILLIPS - 11.16MM LONG X 8.80MM WIDE - CLEAR ----- REPLACE
    1 NUT - CLW - 12MM - 15.70MM WIDE X 6.48MM DEEP - CLEAR
    1 NUT - FLANGE - 12MM - 17.52MM WIDE X 7.56MM DEEP - CLEAR
    T-BOLT CLAMPS: DONE!!
    21 NUTS - NYLON INSERTS - 11MM - 10.97MM WIDE X 7.92MM DEEP - CLEAR
    MAF: DONE
    2 BOLTS - ALLEN HEAD - VH-5 - 30.88MM LONG X 9.97MM WIDE - CLEAR ( REPLACE ) DID NOT PLATE?
    1 BOLT - ALLEN HEAD - VH-5 - 25.90MM LONG X 10.04MM WIDE - CLEAR ( REPLACE )DID NOT PLATE?
    3 NUTS - 10MM - NYLON INSERT - 9.94MM WIDE X 5.88MM DEEP - CLEAR ( REPLACE )DID NOT PLATE?
    2 SCREWS - PHILLIPS - FLANGE HEAD - 16.75MM LONG X 9.63MM WIDE - CLEAR
    COIL PACK: DONE!!
    9 BOLTS - PHILLIPS - CLW - 27.97MM LONG X 8.60MM WIDE - CLEAR
    1 BOLT - PHILLIPS - CW/LW - 14.89MM LONG X 11.83MM WIDE - CLEAR
    1 BOLT - CLW - 12MM - G4 - 19.46MM LONG X 13.85MM WIDE - CLEAR
    SHIFTER CABLE MOUNT - TRANSMISSION: DONE!!
    2 BOLTS - CLW - G7 - 12MM - 30.85MM LONG X 14.08MM WIDE - CLEAR
    TRANSMISSION BALL & SPRING COVER:
    2 BOLTS - 10MM - G (3F/8.8) - 22.34MM LONG X 9.85MM WIDE - CLEAR
    2 WASHERS - 12.24MM WIDE X 1.48MM DEEP X 6.55MM HOLE - CLEAR CANT FIND 2
    BUSTED TRANSMISSION: DONE!!
    2 BOLTS - FLANGE HEAD - G (HP/8.8) - 13MM - 206MM LONG X 17.46MM WIDE - CLEAR
    1 BOLT - FLANGE HEAD - G(HP/8.8) - 13MM - 156MM LONG X 17.30MM WIDE - CLEAR
    1 BOLT - G(3F/8.8) - 13MM - 70.20MM LONG X 13.02MM WIDE - CLEAR
    1 BOLT - FLANGE HEAD - 13MM - 62.94MM LONG X 17.84MM WIDE - CLEAR
    7 BOLTS - FLANGE HEAD - 13MM - 42.93MM LONG X 17.69MM WIDE - CLEAR
    8 BOLTS - FLANGE HEAD - G(DERA/8.8) - 13MM - 37.88MM LONG X 17.75MM WIDE - CLEAR
    2 BOLTS - FLANGE HEAD - 13MM - 48.15MM LONG X 17.56MM WIDE - CLEAR
    1 BOLT - G(RIBE/80) - 13MM - 25.44MM LONG X 12.83MM WIDE - CLEAR
    1 BOLT - CLW - G4 - 12MM - 17.83MM LONG X 14.04MM WIDE - CLEAR
    1 WASHER - ALUMINUM - DISREGARD FOR PLATING
    TRASNSMISSION DRAIN PLUG: DONE
    1 DRAIN PLUG - 17MM - 17.19MM LONG X 22.84MM WIDE - CLEAR
    BATTERY TIE DOWN: DONE!!
    1 TIE DOWN - CLEAR
    1 NUT - SPINNING FLANGE - 10MM - 13.98MM WIDE X 6.25MM DEEP - CLEAR
    SLAVE CYLINDER HARDLINE BRACKET ON TRANS: DONE!!
    1 BOLT - CW/LW - G4 -12MM - 25.54MM LONG X 17.61MM WIDE - CLEAR
    BATTERY TIE-DOWN STUD: COMBINE WITH BATTERY TIE DOWN: DONE
    1 NUT - CW - 10MM - 13.96MM WIDE X 6.35MM DEEP - CLEAR
    FRONT SUBFRAME PLASTIC SHIELD: DONE!!
    2 SCREWS - PHILLIPS - 16.33MM LONG X 13.54MM WIDE - CLEAR
    DS FRONT WHEEL WELL GROUNDING POINT: DONE!
    1 BOLT - FLANGE - G4 - 10MM - 19.98MM LONG X 16.44MM WIDE - CLEAR
    FRONT SUBFRAME NEXT TO PLASTIC SHIELD: DONE!!
    1 BOLT - CLW - G4 - 12MM - 19.49MM LONG X 14.08MM WIDE - CLEAR
    FLYWHEEL: DONE!!
    8 BOLTS - SLIGHT FLANGE - 14MM - NO MARKING - 32.20MM LONG X 17.24MM WIDE - CLEAR
    PS BEHIND SRS SENSOR: DONE!!
    1 BOLT - CW/LW - G (E) - 10MM - 19.93MM LONG X 12.82MM WIDE - CLEAR
    1 BOLT - CLW - G7 - 10MM - 17.85MM LONG X 11.41MM WIDE - CLEAR
    SLAVE CYLINDER: DONE!!
    2 BOLTS - CLW - G7 - 12MM - 30.78MM LONG X 13.94MM WIDE - CLEAR
    MAF: DONE!!
    2 SCREWS - FLANGE - PHILLIPS - 16.85MM LONG X 9.79MM WIDE - CLEAR
    DS MOTOR MOUNT: DONE
    1 PIN/BOLT - 132MM LONG - CLEAR
    3 NUTS - FLANGE - 17MM - 23.43MM WIDE X 13.14MM DEEP - CLEAR
    2 NUTS - CW - 14MM - 21.97MM WIDE X 9.63MM DEEP - CLEAR
    1 NUT - 17MM - 16.92MM WIDE X 10.00MM DEEP - CLEAR
    3 WASHERS - 21.17MM WIDE X 12.24MM HOLE X 1.97MM DEEP - CLEAR
    1 LOCK WASHER - 21.34MM WIDE X 12.70MM HOLE X 3.18MM DEEP - CLEAR
    TRANS TO ENGINE: DONE!!
    1 BOLT - FLANGE - 17MM - 71.58MM LONG X 25.96MM WIDE - CLEAR
    1 BOLT - FLANGE - G7 - 17MM - 66.02MM LONG X 22.14MM WIDE - CLEAR
    4 BOLTS - CLW - 17MM - 48.63MM LONG X 19.96MM WIDE - CLEAR
    FLEX PLATES: DONE!!
    2 BOLTS - FLANGE - G7 - 10MM - 15.68MM LONG X 13.20MM WIDE - CLEAR
    2 BOLTS - CW/LW - G4 - 10MM - 15.87MM LONG X 12.77MM WIDE - CLEAR (SHOULD BE GRADE 7)
    STARTER: DONE
    2 BOLTS - FLANGE - G7 - 14MM - 64.24MM LONG X 18.71MM WIDE - CLEAR
    2 BOLTS - FLANGE - 8MM - 130MM LONG X 10.13MM WIDE - CLEAR
    2 SCREWS - SLIGHT FLANGE - PHILLIPS - 26.20MM LONG X 11.46MM WIDE - CLEAR
    2 SCREWS - SLIGHT FLANGE - PHILLIPS - 11.20MM LONG X 8.82MM WIDE - CLEAR
    1 NUT - FLANGE - 12MMM - 17.44MM WIDE X 7.51MM DEEP - CLEAR
    1 NUT - CLW - 12MM - 15.44MM WIDE X 6.42MM DEEP - CLEAR
    FRONT MOTOR MOUNT: DONE
    1 BOLT - FLANGE - G10 - 14MM - 102.69MM LONG X 18.64MM WIDE - CLEAR
    3 BOLTS - CLW - G10 - 14MM - 31.94MM LONG X 17.06MM WIDE - CLEAR
    1 NUT- SQUISHED SELF LOCKING - 14MM - 14MM WIDE X 10.10MM THICK - CLEAR
    1 LOCK WASHER - 18.40MM WIDE X 10.57MM HOLE X 2.67MM DEEP - CLEAR
    1 WASHER - 20.80MM WIDE X 11.31MM HOLE X 1.49MM THICK - CLEAR
    CRANK PULLEY: DONE!!
    1 BOLT - 22MM - 71.14MM LONG X 25.69MM WIDE - CLEAR
    1 WASHER: 40.74MM WIDE X 14.74MM HOLE X 8.71MM DEEP - CLEAR
    REAR MOTOR MOUNT: DONE
    1 BOLT - 14MM - 107.10MM LONG X 14.25MM WIDE - CLEAR
    4 BOLTS - CLW - G7 - 14MM - 31.43MM LONG X 16.50 MM WIDE - CLEAR
    1 NUT - SQUISHED SELF LOCKING - 14MM - 14.06MM WID EX 10.16MM DEEP - CLEAR
    1 WASHER - 22.38MM WIDE X 9.51MM HOLE X 2.26MM THICK - CLEAR
    1 LOCK WASHER - 18.54MM WIDE X 10.25MM HOLE X 3.24MM THICK - CLEAR
    PS MOTOR MOUNT:
    3 BOLTS - CLW - G7 - 17MM - 37.98MM LONG X 20.21MM WIDE - CLEAR
    4 BOLTS - CLW - G7 - 14MM - 31.34MM LONG X 16.15MM WIDE - CLEAR
    BACK OF PS CRASHBAR STRUCTURE: DONE!!
    1 BOLT - CW/LW - G7 - 12MM - 25.61MM LONG X 21.80MM WIDE - CLEAR
    SLAVE CYLINDER ASSEMBLY: DONE!!
    1 BANJO BOLT - G(3.5) - 14MM - 32.56MM LONG X 13.88MM WIDE - CLEAR
    1 BLEEDER SCREW - 33.68MM LONG X 9.90MM WIDE - CLEAR
    1 BANJO JOINT - CLEAR
    1 PUSH ROD - 73.81MM LONG X 7.83MM WIDE - CLEAR
    EXTERIOR FIREWALL UNDER STEERING COLUMN: DONE!!
    1 BOLT - CLW - G4 - 12MM - 21.73MM LONG X 14.04MM WIDE - CLEAR
    LOWER TIMING BELT COVER: DONE!!
    1 BOLT - FLANGE - G7 - 10MM - 40.81MM LONG X 12.95MM WIDE - CLEAR
    7 BOLTS - FLANGE - G7 - 10MM - 25.63MM LONG X 12.95MM WIDE - CLEAR
    FRONT TURBO TO MANIFOLD ( NEED 1): DONE!!
    2 BOLTS - FLANGE - BLANK HEAD - 14MM - 44.84MM LONG X 18.84MM WIDE - CLEAR
    FRONT MOTOR MOUNT BRACKET: DONE
    1 BOLT - CLW - 17MM - 38.44MM LONG X 20.25MM WIDE - CLEAR
    2 BOLTS - CLW - 14MM - 32.57MM LONG X 17.29MM - CLEAR
    3 BOLTS - CLW - G7 - 14MM - 26.75MM LONG X 17.05MM WIDE - CLEAR
    REAR TURBO WASTEGATES: DONE!!
    2 BOLTS - CLW - G7 - 12MM - 21.59MM LONG X 13.87MM WIDE - CLEAR
  5. The Following User Says Thank You to 99ishVR-4 For This Useful Post:
  6. #4
    Engine Bay cont.
    REAR 02 HOUSING: DONE!!
    4 NUTS - FLANGE - 14MM - 18.68MM WIDE X 10.30MM DEEP - CLEAR
    2 NUTS - 19MM - 18.98MM WIDE X 11.63MM DEEP - CLEAR
    OIL RETURN LINES - OIL PAN:
    4 BOLTS - CW - G7 - 10MM - 24MM LONG X 12.97MM WIDE - CLEAR CANT FIND 4
    WATER NECK: DONE!!
    2 BOLTS - CLW - G7 - 12MM - 31MM LONG X 14.20MM WIDE - CLEAR
    LOWER PLENUM: DONE!!
    1 BOLT - FLANGE - G7 - 12MM - 22.15MM LONG X 15.90MM WIDE - CLEAR
    8 NUTS - FLANGE - 12MM - 16.61MM WIDE X 9.01MM DEEP - CLEAR
    8 WASHER STACKS - 18.49MM WIDE X 8.07MM HOLE X 10.51MM DEEP - CLEAR
    FRONT TURBO WASTEGATE: DONE!!
    ALTERNATOR ANGLE BRACKET: DONE!!
    2 BOLTS - FLANGE - G7 - 12MM - 28.30MM LONG X 16.40MM WIDE - CLEAR
    EXHAUST MANIFOLDS:
    14 NUTS - SQUISHED SELF LOCKING - 14MM - 14.08MM WIDE X 10.15MM DEEP - CLEAR
    10 WASHERS - 20.03MM WIDE X 10.36MM HOLE X 1.92MM DEEP - CLEAR
    4 WASHERS - CONED DISC - 20.05MM WIDE X 10.76MM HOLE X 2.57MM THICK - CLEAR CANT FIND 1
    3 WASHERS - 20.70MM WIDE X 10.65MM HOLE X 3.23MM THICK - CLEAR
    FRONT TURBO OIL & COOLANT LINES: DONE!!
    2 BANJO BOLTS - 19MM - 30.04MM LONG X 18.97MM WIDE - CLEAR
    2 BANJO BOLTS - 17MM - 25.99MM LONG X 16.97MM WIDE - CLEAR
    2 BOLTS - CLW - 10MM - 19.977MM LONG X 11.16MM WIDE - CLEAR
    THERMOSTAT COVER: DONE!!
    1 BOLT - CLW - G7 - 12MM - 55.87MM LONG X 13.91MM WIDE - CLEAR
    WATER HOUSING: DONE!!
    4 BOLTS - CLW - G7 - 12MM - 35.77MM LONG X 14.13MM WIDE - CLEAR
    ALTERNATOR BRACKET: DONE!!
    1 BOLT - FLANGE - G7 - 14MM - 39.72MM LONG X 18.38MM WIDE - CLEAR
    2 BOLTS - FLANGE - G7 - 12MM - 33.80MM LONG X 15.62MM WIDE - CLEAR
    SPIDERWEB BRACKET: DONE!!
    2 BOLTS - CW/LW - 14MM - 62.08MM LONG X 21.60MM WIDE - CLEAR
    2 BOLTS - CW/LW - 14MM - 51.97MM LONG X 21.65MM WIDE - CLEAR
    2 BOLTS - CLW - 14MM - 37.02MM LONG X 17.10MM WIDE - CLEAR
    ACCESSORY IDLER PULLEY: DONE?
    1 BOLT - CLW - G7 - 14MM - 41.66MM LONG X 17.17MM WIDE - CLEAR
    ACCESSORY BELT TENSIONER BRACKET: DONE!!
    1 BOLT - CW/LW - G7 - 12MM - 105.75MM LONG X 17.86MM WIDE - CLEAR
    2 BOLTS - CW/LW - G7 - 12MM - 31MM LONG X 17.69MM WIDE - CLEAR
    THROTTLE BODY: CANT FIND PIECES
    4 BOLTS - PHILLIPS - CLW - 38.11MM LONG X 9.30MM WIDE - CLEAR
    1 BOLT - PHILLIPS - CLW - 21.13MM LONG X 9.23MM WIDE - CLEAR
    2 BOLTS - CW/LW - 8MM/PHILLIPS - 22.22MM LONG X 9.60MM WIDE - CLEAR
    2 BOLTS - CW/LW - 8MM/PHILLIPS - 17.27MM LONG X 10.71MM WIDE - CLEAR
    1 BOLT - PHILLIPS - 30.18MM LONG X 7.50MM WIDE - CLEAR CANT FIND
    2 SCREWS - PHILLIPS - 10.07MM LONG X 7.69MM WIDE - CLEAR
    1 BISS SCREW - PHILLIPS - CLEAR
    1 NUT - 12MM - 11.76MM WIDE X 4.05MM DEEP - CLEAR
    1 NUT - 10MM - 9.81MM WIDE X 3.46MM DEEP - CLEAR
    1 NUT - 8MM - 7.86MM WIDE X 3.09MM DEEP - CLEAR
    1 LOCK WASHER - 11.66MM WIDE X 5.92MM HOLE X 1.47MM DEEP - CLEAR CANT FIND
    1 BRACKET - MARKED G - CLEAR
    1 SPRING - CLEAR
    REAR TURBO INTERCOOLER PIPE: DONE!!
    1 BOLT - CW/LW - G10 - 12MM - 25.39MM LONG X 17.63MM WIDE - CLEAR
    POWER STEERING PUMP: DONE!!
    1 BOLT - CW/LW - 14MM - LONG HEAD - 89.74MM LONG X 25.57MM WIDE - CLEAR
    1 BOLT - CLW - 14MM - LONG HEAD - 61.11MM LONG X 20.60MM WIDE - CLEAR
    1 BOLT - CW/LW - G7 -14MM - 31.52MM LONG X 25.64MM WIDE - CLEAR
    1 NUT - 14MM - 13.97MM WIDE X 7.99MM DEEP - CLEAR
    1 LOCK WASHER - 17.99MM WIDE X 10.40MM HOLE X 2.52MM DEEP - CLEAR
    REAR TURBO OIL & WATER LINES: DONE!!
    1 BANJO BOLT - 19MM - 46.01MM LONG X 18.92MM WIDE - CLEAR
    1 BANJO BOLT - 19MM - 30.02MM LONG X 18.98MM WIDE - CLEAR
    1 BANJO BOLT - 17MM - 26MM LONG X 16.85MM WIDE - CLEAR
    2 BOLTS - G7 - CLW - 10MM - 19.88MM LONG X 11MM WIDE - CLEAR
    1 RESTRICTOR VALVE - 19MM - 19.01MM WIDE X 27.28MM TALL - CLEAR
    REAR TURBO TO MANIFOLD:!!
    3 NUTS - FLANGE - 14MM - 18.75MM WIDE X 10.03MM DEEP - CLEAR
    3 WASHERS - 20.03MM WIDE X 10.23MM HOLE X 1.85MM DEEP - CLEAR CANT FIND 3
    FRONT TRANNY STAY/TURBO SUPPORT: DONE!!
    2 BOLTS - CLW - 17MM - 33MM LONG X 20.21MM WIDE - CLEAR
    1 BOLT - CLW - 17MM - 28.34MM LONG X 19.88MM WIDE - CLEAR
    2 NUTS - 14MM - 18.76MM WIDE X 10.16MM DEEP - CLEAR
    RADIATOR HOSES: DONE!!
    4 HOSE CLAMP BOLTS - 10MM - PHILLIPS - 39.44MM LONG X 22.47MM WIDE - CLEAR
    4 HOSE CLAMPS 47MM WIDE X 12MM DEEP - CLEAR
    TENSIONER PULLEY & PULLEY SWINGARM & TENSIONER: DONE!!
    2 BOLTS - FLANGE - G7 - 12MM - 77.90MM LONG X 15.87MM WIDE - CLEAR
    1 BOLT - FLANGE - G7 - 14MM - 70.64MM LONG X 18.62MM WIDE - CLEAR
    1 BOLT - CW/LW - G7 - 14MM - 41.78MM LONG X 21.69MM WIDE - CLEAR
    1 WASHER - 27.88MM WIDE X 11.14MM HOLE X 3.06MM THICK - CLEAR
    UNDERBODY LINE BUNLE BRACKET NEAR FUEL FILTER: DONE!!
    1 NUT - SPINNING FLANGE - 12MM - 18MM WIDE X 8.13MM DEEP - CLEAR
    FRONT TRANNY STAY / TURBO SUPPORT: WHY DUPLICATE?
    2 BOLTS - CLW - 17MM - 33.10MM LONG X 20.18MM WIDE - CLEAR CANT FIND 2
    1 BOLT - CLW - 17MM - 28.28MM LONG X 20.08MM WIDE - CLEAR
    1 NUT - FLANGE - 14MM - 18.67MM WIDE X 10.05MM DEEP - CLEAR
    IDLER PULLEY / PULLEY BRACKET: DONE!!
    3 BOLTS - CLW - 14MM - 32.10MM LONG X 17.18MM WIDE - CLEAR
    1 BOLT - FLANGE - G8 - 14MM - 35.08MM LONG X 18.63MM WIDE - CLEAR
    WATER PUMP: DONE!!
    1 BOLT - FLANGE - G7 - 12MM - 30.33MM LONG X 16.05M WIDE - CLEAR
    5 BOLTS - FLANGE - G7 - 10MM - 21.14MM LONG X 12.71MM WIDE - CLEAR
    1 BOLT - FLANGE - G7 - 12MM - 22.23MM LONG X 16.07MM WIDE - CLEAR
    POWER STEERING PUMP BRACKET: DONE!!
    2 BOLTS - CW/LW - 14MM - 37.14MM LONG X 21.79MM WIDE - CLEAR
    2 BOLTS - CLW - G7 - 12MM - 30.68MM LONG X 13.98MM WIDE - CLEAR (ADJUSTED BAG TO 2 BOLTS)
    DS MOTOR MOUNT BLOCK: DONE
    1 BOLT - G "R" - 17MM - 104.23MM LONG X 17.05MM WIDE - CLEAR
    1 BOLT G "H" 17MM - 77.94MM LONG X 16.93MM WIDE - CLEAR
    1 BOLT G "H" - 17MM - 74.20MM LONG X 16.93MM WIDE - CLEAR
    3 STUDS - 78.47MM LONG X 11.88MM WIDE - CLEAR
    AC COMPRESSOR ASSEMBLY: DONE!!
    4 BOLTS - FLANGE - 12MM - 51.98MM LONG X 16.75MM WIDE - CLEAR
    5 BOLTS - FLANGE - 10MM - 35.70MM LONG X 13.62MM WIDE - CLEAR
    8 BOLTS - FLANGE - G8 - 10MM - 25.40MM LONG X 12.92M WIDE - CLEAR
    1 BOLT - FLANGE - 10MM - 40.65MM LONG X 13.43MM WIDE - CLEAR
    12 BOLTS - 8MM - 9.89MM LONG X 7.99MM WIDE - CLEAR (6 ARE EXTRA)
    1 SCREW - CLW - PHILLIPS - 10.39MM LONG X 6.68MM WIDE - CLEAR
    2 NUTS - SELF LOCKING - 14MM - 13.96MM WIDE X 7.30MM DEEP - CLEAR (1 IS EXTRA)
    2 WASHERS - 14MM WIDE X 10.05MM HOLE X .44MM THICK - CLEAR
    1 SNAP RING - 43MM WIDE X 1.83MM THICK - CLEAR
    POWER STEERING BELT TENSIONER (EXTRA?)
    1 BOLT - CLW - G7 - 14MM - 61.72MM LONG X 20.40MM WIDE - CLEAR
    CAM GEARS: DONE!!
    4 BOLTS - FLANGE - G7 - 17MM - 41.32MM LONG X 22.55MM WIDE - CLEAR
    BOTTOM PS FRAME RAIL - ENGINE BAY - DONE!!
    1 BOLT - CW/LW - G4 - 12MM - 25.43MM LONG X 12.64MM WIDE - CLEAR
    KNOCK SENSOR BRACKET: DONE!!
    4 BOLTS - FLANGE - G4 - 14MM - 29.64MM LONG X 18.65MM WIDE - CLEAR
    OIL FILTER HOUSING: DONE!!
    2 BANJO BOLTS - G6 - 24MM - 40.64MM LONG X 23.82MM WIDE - CLEAR
    1 BOLT - FLANGE - G7 - 12MM - 63.17MM LONG X 16.06MM WIDE - CLEAR
    2 BOLTS - FLANGE - G7 - 12MM - 38.21MM LONG X 15.96MM WIDE - CLEAR
    HORN BRACKET ASSEMBLY: DONE!!
    2 BOLTS - CW/LW - PHILLIPS - 12MM - 21.73MM LONG X 17.60MM WIDE - CLEAR
    1 BOLT - CW/LW - G7 - 10MM - 17.88MM LONG X 12.81MM WIDE - CLEAR
    PCV VALVE HOSE: DONE!!
    2 SPRING HOSE CLAMPS - 15.21MM WIDE X 12.04MM DEEP - CLEAR
    OEM POSITIVE BATTERY TERMINAL: DONE!!
    1 BOLT - SQUARE HEAD - 25.66MM LONG X 11.87MM WIDE - CLEAR
    1 NUT - 10MM - 10.14MM WIDE X 7.5MM DEEP - CLEAR
    TRANSMISSION DRAIN PLUG: DONE!!
    1 BOLT - FLANGE - 17MM - 19.56MM LONG X 23MM WIDE - CLEAR
    CLUTCH ASSEMBLY: DONE
    20 BOLTS - FLANGE - ALLEN - vH5 - 21.75MM LONG X 12.14MM WIDE - BLACK
    PS MOTOR MOUNT PIN: DONE!!
    1 BOLT - G7 - 17MM - 127MM LONG X 17.03MM WIDE - CLEAR
    1 NUT - 17MM - 17.04MM WIDE X 9.91MM DEEP - CLEAR
    1 LOCK WASHERS - 21.09MM WIDE X 12.53MM HOLE X 3.13MM THICK - CLEAR
  7. The Following User Says Thank You to 99ishVR-4 For This Useful Post:
  8. #5
    Engine Bay cont.
    BRAKE BOOSTER HOSE: DONE!!
    2 SPRING HOSE CLAMPS - 17.85MM WIDE X 10.07MM DEEP - CLEAR
    THROTTLE CABLE ASSEMBLY: (TRY TO USE MATCHING WASHERS IF POSSIBLE) DONE!!
    2 NUTS - 14MM - 13.93MM WIDE X 6MM DEEP - BLACK
    1 WASHER - 25.46MM WIDE X 11.21MM HOLE X 1.99MM THICK - CLEAR
    1 WASHER - 21.61MM WIDE X 10.56MM HOLE X 1.67MM THICK - CLEAR
    WATER CROSSOVER PIPE: DONE!!
    1 BOLT - FLANGE - G4 - 12MM - 24.04MM LONG X 15.78MM WIDE - CLEAR - TOO LONG
    1 BOLT - FLANGE - G4 - 12MM - 19.39MM LONG X 15.68MM WIDE - CLEAR
    REAR MOTOR MOUNT BRACKET / TRANNY STAY / TURBO BRACKET:
    1 NUT - SQUISHED SELF LOCKING - 17MM - 18.89MM WIDE X 11.54MM DEEP - CLEAR
    1 WASHER - 17.96MM WIDE X 8.52MM HOLE X 1.94MM THICK - CLEAR
    2 BOLTS - CLW - 17MM - 43.04MM LONG X 20MM WIDE - CLEAR
    2 BOLTS - CLW - 14MM - 32.01MM LONG X 17.16MM WIDE - CLEAR
    METAL TIMING BELT COVERS: DONE!!
    4 BOLTS - FLANGE - G7 - 12MM - 20.06MM LONG X 16.02MM WIDE - CLEAR
    4 BOLTS - FLANGE - G7 - 10MM - 17.50MM LONG X 12.97MM WIDE - CLEAR
    3 BOLTS - FLANGE - G7 - 10MM - 25.96MM LONG X 13.04MM WIDE - CLEAR
    2 BOLTS - FLANGE - G7 - 10MM - 23.86MM LONG X 13.08MM WIDE - CLEAR
    RADIATOR FANS MOUNTING: DONE!!
    8 BOLTS - CW/LW - PHILLIPS/10MM - 19.78MM LONG X 15.85MM WIDE - CLEAR
    EXTRA - 2 BOLTS - CW/LW - G4 - 10MM - 20.15MM LONG X 17.66MM WIDE - CLEAR
    FRONT O2 HOUSING:
    3 NUTS - 14MM - FLANGE - 18.69MM WIDE X 10.10MM DEEP - CLEAR - MISSING 1 CANT FIND 3
    2 NUTS - SQUISH SELF LOCKING - 19MM - 18.87MM WIDE X 11.40MM DEEP - CLEAR
    LOWER FLYWHEEL SHIELD: DONE!!
    2 BOLTS - CW - PHILLIPS/10MM - 13.88MM LONG X 15.67MM WIDE - CLEAR
    BLOCK COOLANT DRAINS: DONE!!
    2 BOLTS - G4 - 14MM - 22.22MM LONG X 14.11MM WIDE - CLEAR
    DIP STICK TUBE: DONE!!
    1 BOLT - FLANGE - G4 - 12MM - 20.19MM LONG X 15.90MM WIDE - CLEAR
    WATER BLOCKOFF PLATES: DONE!!
    4 BOLTS - CLW - G4 - 12MM - 25.59MM LONG X 14.08MM WIDE - CLEAR
    OIL PAN: DONE!!
    16 BOLTS - FLANGE - G7 - 18.16MM LONG X 13.12MM WIDE - CLEAR
    CAS:
    2 BOLTS - FLANGE - G7 - 12MM - 28.27MM LONG X 16.06MM WIDE - CLEAR
    1 NUT - FLANGE - 12MM - 16.97MM WIDE X 8.92MM DEEP - CLEAR
    2 SCREWS - CW/LW - ONE-WAY FLATHEAD - 16.26MM LONG X 7.72MM WIDE - CLEAR
    2 SCREWS - CLW - PHILLIPS - 12.40MM LONG X 6.56MM WIDE - CLEAR CANT FIND 2
    1 WASHER - 23.77MM WIDE X 8.63MM HOLE X 1.96MM THICK - CLEAR
    FRONT VALVE COVER: DONE
    11 BOLTS - CLW - G7 - 10MM - 29.15MM LONG X 10.87MM WIDE - CLEAR
    REAR VALVE COVER: DONE!!
    10 BOLTS - CLW - G7 - 10MM - 29.14MM LONG X 11.12MM WIDE - CLEAR ON CAR
    4 BOLTS - CLW - G7 - 10MM - 16.04MM LONG X 11.13MM WIDE - CLEAR
    1 BOLT - CLW - G7 - 10MM - 63.68MM LONG X 11.02MM WIDE - CLEAR ON CAR
  9. The Following User Says Thank You to 99ishVR-4 For This Useful Post:
  10. #6
    Underbody
    Underbody photobucket album: Mitsubishi 3000gt Nuts And Bolts - Underbody Photos by mudvaynedude122 | Photobucket
    ps plasic fuel line guard: Done!!
    3 nuts - spinning flange - 12mm - 20mm wide x 10mm deep - clear
    2 screws - slight flange head - 16mm long x 15mm wide - phillips - clear
    fuel line covers: Done!!
    3 nuts - spinning flange - 12mm - 20mm wide x 9mm thick - clear
    front brake lines clips: Done!!
    6 clips (clear)
    front camber bolts: Done
    2 camber bolts - g10 - 17mm - clear (bake)
    2 nuts - 17mm - 17mm wide x 8mm deep - clear (bake)
    2 lock washers - 22mm wide - clear (bake)
    front brake dust shields: Done!!
    3 bolts - clear - g7 - 10mm - 16mm long x 17mm wide - clear (bake)
    fuel filler tube: Done?
    3 bolts - clw - g4 - 12mm - 25mm long x 15mm wide - clear
    3 screws - cw/lw - 21mm long x 14mm wide - phillips - black
    2 hose clamp bolts - 10mm - 40mm long x 24mm wide - phillips - clear
    2 hose clamps - 60mm wide - clear
    2 spring hose clamps - 22mm wide x 13mm deep - clear
    ds rear wheel well cover ( splash guard): Done!!
    3 bolts - cw/lw - g4 - 10mm - 26mm long x 18mm wide - black
    1 bolt - cw - g4 - 10mm - 21mm long x 19mm wide - black
    underbody plastic:
    2 bolts - cw/lw - g4 - 12mm - 25mm long x 25mm wide - black
    3 screws - bolt heads - cw - g(9.8/5) 10mm - 30mm long x 17mm wide - black
    1 bolt - cw/lw - g4 - 10mm - 20mm long x 18mm wide - black cant find 1
    fuel filler guard: Done!!
    2 bolts - clw - 10mm - 20mm long x 12mm wide - phillips - clear
    ps rear wheel well cover:
    3 bolts - cw/lw - g4 - 10mm - 25mm long x 19mm wide - black
    1 bolt - cw/lw g4 - 10mm - 22mm long x 26mm wide - black
    fuel pump assembly: Done!!
    2 screw bolts - 11mm long x 9mm wide - phillips - clear
    2 screw bolts - 9mm long x 7mm wide - phillips - clear
    2 screw bolts - cw/lw - 15mm long x 8mm wide - phillips - clear
    4 nuts - 7mm - 7mm wide x 4mm deep - clear
    1 nut - clw - 8mm - 10 mm wide x 7mm deep - clear
    2 nuts - clw - 7mm - 9mm wide x 5mm deep - clear
    1 bracket - fuel pump holder - clear
    1 bracket - fuel float holder - clear
    fuel feed hose & extra:
    2 fueel feed hoses - 250mm long - clear
    ds rear brake caliper mounting & lines: Done!!
    2 bolts - g10 - 14mm - 32mm long x 13mm wide - clear (bake)
    2 lock washers - 20mm wide - clear (bake)
    3 brake line clips - 26mm wide x 27mm tall - clear
    1 bolt - clw - g4 - 12mm - 21mm long x 15mm wide - clear
    front shock brake line clips: Done!!
    4 clips - 26mm wide x 27mm tall - clear
    ps rear brake caliper: Done!!
    2 bolts - clw - g4 -12mm - 20mm long x 15mm wide - clear
    3 clips - 26mm wide x 27mm tall - clear
    rear fuel line bundle bracket: Done!!
    1 bolt - clw - g4 - 12mm - clear - 22mm long x 15mm wide
    gas tank: Done!!
    2 bolts - cw/lw - g4 - 12mm - 21mm long x 21mm wide - clear
    5 nuts - flange - 14mm - 21mm wide x 10mm deep - clear
    9 nuts - spinning flange - 8mm - 11mm wide x 5mm deep - clear
    2 hose spring clamps - 20mm wide x 12mm deep - clear
    2 hose spring clamps - 13mm wide x 8mm deep - clear
    6 hose spring clamps - 12mm wide x 8mm deep - clear
    front brake calipers: Done!!
    2 bolts - g(8.8) - 19mm - 42mm long x 21mm wide - clear (wrong bolts)
    4 pins - clear
    3 spacers - clear
    8 boot rings - clear
    2 springs brackets - clear (bake)
    2 wire ping holder - clear
    2 bleeders - 10mm - 40mm long x 12mm wide - clear
    8 bolts - flange - g9 - 14mm - 114.52mm long x 19.50 wide - clear
    gas tank drain plug: Done!!
    1 bolt - g7 - 12mm - flange - 19mm long x 16mm wide - clear - needs crush washer
  11. #7
    Underbody cont.
    REAR SWAY BAR END LINKS: DONE!!
    2 NUTS - SPINNING FLANGE - 14MM - 21.91MM WIDE X 9.91MM DEEP - CLEAR
    2 NUTS - 14MM - 14.25MM WIDE X 10.21MM DEEP - CLEAR
    4 BUSHING WASHERS - 32.06MM WIDE X 10.38MM HOLE X 4.66MM DEEP - CLEAR
    2 BUSHING WASHERS - 32.11MM WIDE X 12.50MM HOLE X 6.23MM DEEP - CLEAR
    EBRAKE / ABS SENSOR CABLE SUPPORTS: DONE!!
    9 BOLTS - CLW - G4 - 12MM - 21.70MM LONG X 14.09MM WIDE - CLEAR
    3 BOLTS - CLW - G4 - 12MM - 12.51MM LONG X 14.05MM WIDE - CLEAR
    1 BOLT - CLW - G4 - 12MM - 25.53MM LONG X 14.04MM WIDE - CLEAR
    REAR SUBFRAME STUDS: DONE
    6 BOLTS - CLW - G7 - 17MM - 33.10MM LONG X 20.12MM WIDE - CLEAR
    AWS JUNCTION BLOCK: DONE!!
    3 BOLTS - G4 - CLW - 25.41MM LONG X 14.12MM WIDE - CLEAR
    AWS LINE BRACKETS: DONE!!
    6 BOLTS - CLW - G4 - 12MM - 19.64MM LONG X 14.06MM WIDE - CLEAR
    1 BOLT -CLW - G4 - 12MM - 25.49MM LONG X 14.12MM WIDE - CLEAR
    2 HOSE CLAMP BOLTS - 10MM / PHILLIPS - 39.41MM LONG X 22.75MM WIDE - CLEAR
    2 HOSE CLAMP BANDS - 23.58MM TALL X 11.87MM WIDE - CLEAR
    REAR SUBFRAME: DONE
    2 BOLTS - CLW - G7 - 17MM - 33.19MM LONG X 20.11MM WIDE - CLEAR
    2 NUTS - FLANGE - 19MM - 27.12MM WIDE X 15.97MM DEEP - CLEAR
    2 NUTS - 22MM - 22.15MM WIDE X 16.18MM DEEP - CLEAR
    2 WASHERS - 66.74MM WIDE X 14.27MM HOLE X 8.96MM DEEP - CLEAR
    REAR AXLES: DONE!!
    8 BOLTS - G 10.9 - 14MM - 36.12MM LONG X 13.94MM WIDE - CLEAR
    8 NUTS - 14MM - 14.07MM WIDE X 8.06MM DEEP - CLEAR
    8 LOCK WASHERS - 18.68MM WIDE X 10.40MM HOLE X 3.18MM THICK - CLEAR
    REAR DIFF: DONE!!
    4 BOLTS - 17MM - G8 - 78.38MM LONG X 16.94MM WIDE - CLEAR
    3 BOLTS - FLANGE - G8 - 17MM - 39.70MM LONG X 24.14MM WIDE - CLEAR
    6 BOLTS - FLANGE - G8 - 17MM - 31.58MM LONG X 24.30MM WIDE - CLEAR
    4 NUTS - 17MM - 17.54MM WIDE X 10.09MM DEEP - CLEAR
    4 LOCK WASHERS - 21.91MM WIDE X 12.49MM HOLE X 3.84MM THICK - CLEAR
    REAR SWAY BAR BUSHINGS: DONE!!
    4 BOLTS - CLW - G4 - 12MM - 21.79MM LONG X 14.03MM WIDE - CLEAR
    AWS RACK:
    4 BOLTS - CLW - G4 - 17MM - 27.83MM LONG X 20.03MM WIDE - CLEAR CANT FIND 1
    2 NUTS - 17MM - 17.11MM WIDE X 10MM DEEP - CLEAR
    LOCKWASHERS IN PICTURES?
    REAR-MOST UNDERBODY HEATSHIELD: DONE!!
    3 BOLTS - FLANGE - G4 - 10MM - 15.91MM LONG X 16.63MM WIDE - CLEAR
    SLANTED HEATSHIELD INFRONT OF GAS TANK: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 25.50MM LONG X 14.25MM WIDE - CLEAR
    REAR DRIVER SIDE BRAKE LINE: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 19.96MM LONG X 14.10MM WIDE - CLEAR
    REAR ABS SENSORS: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 19.44M LONG X 14.09MM WIDE - CLEAR
    REAR SHOCKS: DONE
    2 BOLTS - FLANGE - G8 - 17MM - 39.64MM LONG X 23.80MM WIDE - CLEAR
    4 NUTS - FLANGE - 14MM - 19.30MM WIDE X 10.44MM DEEP - CLEAR
    2 NUTS - 14MM - 13.94MM WIDE X 6MM DEEP - CLEAR
    2 LOCK WASHERS (FLATTENED) - 24.94MM WIDE X 12.95MM HOLE X 2.87MM THICK - CLEAR
    2 WASHERS - 44.84MM WIDE X 12.58MM HOLE X 4.08MM THICK - CLEAR
    LARGE HEATSHIELD UNDERCAR: DONE!!
    5 BOLTS - FLANGE - G4 - 10MM - 15.95MM LONG X 16.54MM WIDE - CLEAR
    FRONT WHEEL BEARINGS: DONE
    8 BOLTS - G10 - 17MM - 62.21MM LONG X 16.73MM WIDE - CLEAR
    8 LOCK WASHERS - 21.74MM WIDE X 12.63MM HOLE X 3.86MM THICK - CLEAR
    REAR CONTROL ARMS (LONG) DONE
    2 NUTS - 22MM - NYLON INSERT - 21.93MM WIDE X 16.02MM TALL - CLEAR
    FRONT ABS SENSORS: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 19.45MM LONG X 14.02MM WIDE - CLEAR
    FRONT SWAY BAR BUSHINGS: DONE!!
    4 BOLTS - CLW - G7 - 14MM - 31.56MM LONG X 16.48MM WIDE - CLEAR
    REAR ABS WIRE SUPPORTS: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 19.59MM LONG X 14.08MM WIDE - CLEAR
    REAR CONTROL ARMS (SHORT): DONE
    2 NUTS - 22MM - NYLON INSERTS - 21.01MM WIDE X 16.19MM TALL - CLEAR
    FRONT AXLE NUTS: DONE
    2 CASTLE NUTS - 32MM - 31.49MM WIDE X 21.25MM TALL - CLEAR
    2 LOCK WASHERS - 42.94MM WIDE X 22.87MM HOLE X 5.42MM THICK - CLEAR
    REAR SUBFRAME ASSEMBLY - BIGGEST BOLTS: DONE
    2 CAMBER BOLTS - 24MM - 92.57MM LONG X 37.03MM WIDE - CLEAR
    2 NUTS - 24MM - 23.98MM WIDE X 13.22MM TALL - CLEAR
    2 ECCENTRIC WASHERS - 36.87MM WIDE X 16.22MM HOLE X 3.36MM THICK - CLEAR
    2 LOCK WASHERS - 26.81MM WIDE X 16.48MM HOLE X 2.79MM THICK - CLEAR
    REAR SUBFRAME ASSEMBLY - SMALLER CAMBER BOLTS: DONE
    2 CAMBER BOLTS - 22MM - 94.56MM LONG X 37.34MM WIDE - CLEAR
    2 NUTS - 22MM - 22.14MM WIDE X 11.24MM TALL - CLEAR
    2 ECCENTRIC WASHERS - 37.45MM WIDE X 14.28MM HOLE X 3.19MM THICK - CLEAR
    2 LOCK WASHERS - 23.54MM WIDE X 14.49MM HOLE X 2.46MM THICK - CLEAR
    REAR SUBFRAME ASSEMBLY BOLTS: DONE
    2 BOLTS - G8 - 22MM - 84.31MM LONG X 21.81MM WIDE - CLEAR
    2 NUTS - 22MM - 22MM WIDE X 11.07MM TALL - CLEAR
    2 LOCK WASHERS - 23.49MM WIDE X 14.55MM HOLE X 2.46MM THICK - CLEAR
    FRONT SWAY BAR: DONE!!
    4 NUTS - SPINNING FLANGE - 14MM - 21.90MM WIDE X 9.86MM TALL - CLEAR
    POWER STEERING RACK: DONE
    4 BOLTS - CLW - G7 - 17MM - 33.22MM LONG X 20.17MM WIDE - CLEAR
    FRONT POWER STEERING LINE BRACKETS ON SUBFRAME:
    1 BOLT - CLW - G7 - 12MM - 21.91MM LONG X 13.41MM WIDE - CLEAR CANT FIND 1
    2 BOLTS - CLW - G4 - 12MM - 19.46MM LONG X 14.13MM WIDE - CLEAR
  12. #8
    Underbody cont.
    FRONT CONTROL ARMS: DONE
    2 BOLTS - FLANGE - G10 - 17MM - 143MM LONG X 24.15MM WIDE - CLEAR
    2 BOLTS - FLANGE - G7 - 17MM - 39.25MM LONG X 23.71MM WIDE - CLEAR
    2 NUTS - 22MM - 21.95MM WIDE X 11.12MM TALL - CLEAR
    2 NUTS - 17MM - 17.07MM WIDE X 9.96MM TALL - CLEAR
    4 NUTS - BUTTOM TOP - 14MM - 14.09MM WIDE X 10.18MM TALL - CLEAR
    2 WASHERS - 29.64MM WIDE X 15.20MM HOLE X 2.92MM THICK - CLEAR
    2 LOCK WASHERS - 24.11MM WIDE X 14.42MM HOLE X 3.68MM THICK - CLEAR
    2 LOCK WASHERS - 21.77MM WIDE X 12.68MM HOLE X 3.82MM THICK - CLEAR
    4 LOCK WASHERS - 18.11MM WIDE X 10.42MM HOLE X 2.65MM THICK - CLEAR
    FRONT STRUTS (MISSING 1 NUT) DONE
    2 CAMBER BOLTS - G10 - 17MM - 71.58MM LONG X 29.96MM WIDE - CLEAR
    2 BOLTS - G10 - 17MM - 65.36MM LONG X 16.80MM WIDE - CLEAR
    3 NUTS - 17MM - 17.08MM WIDE X 9.95MM TALL - CLEAR
    6 NUTS - FLANGE - 14MM - 19.44MM WIDE X 10.53MM TALL - CLEAR
    4 LOCK WASHERS - 21.73MM WIDE X 12.75MM HOLE X 3.78MM THICK - CLEAR
    FRONT SUBFRAME: DONE
    2 BOLTS - FLANGE - G10 - 17MM - 102.03MM LONG X 23.52MM WIDE - CLEAR
    4 NUTS - FLANGE - 17MM - 23.65MM WIDE X 13.20MM TALL - CLEAR
    2 LARGE PLATES - 66.45MM WIDE X 12.22MM HOLE X 4.65MM THICK - CLEAR
    2 SMALLER PLATES - 61.36MM WIDE X 12.22MM HOLE X 4.85MM THICK - CLEAR
    FRONT LOWER BALL JOINTS: DONE
    2 NUTS - 19MM - NYLON INSERTS - 18.96MM WIDE X 14.35MM TALL - CLEAR
    REAR BRAKE DUST SHIELDS: DONE!!
    4 BOLTS - FLANGE - G10 - 12MM - 26.03MM LONG X 15.88MM WIDE - CLEAR
    2 NUTS - 17MM - 17.07MM WIDE X 10.12MM DEEP - CLEAR
    2 LOCK WASHERS - 21.52MM WIDE X 12.63MM HOLE X 3.85MM THICK - CLEAR
    4 LOCK WASHERS - 18.71MM WIDE X 10.53MM HOLE X 3.21MM THICK - CLEAR
    REAR TRAILING ARM BUSHINGS: DONE
    2 BOLTS - G10 - 19MM - 75.73MM LONG X 18.92MM WIDE - CLEAR
    2 NUTS - 17MM - 17.09MM WIDE X 9.96MM DEEP - CLEAR
    2 LOCK WASHERS - 21.14MM WIDE X 12.56MM HOLE X 3.09MM THICK - CLEAR
    PS E-BRAKE SHOE ASSEMBLY: DONE!!
    1 BRACKET - 26.46MM WIDE - CLEAR
    1 BOLT - 26.84MM LONG X 14.07MM WIDE - CLEAR
    1 CLAW - 8.01MM LONG X 13.91MM WIDE - CLEAR
    1 THREADED BODY - 32.31MM LONG X 16.85MM WIDE - CLEAR
    2 WASHER CAPS - 15.90MM WIDE X 4.37MM THICK - CLEAR
    1 BRACKET - 28.11MM WIDE X 20.26MM TALL X 1.95MM THICK - CLEAR
    1 BLUE SPRING - 53.79MM LONG X 9.92MM WIDE - CLEAR
    1 YELLOW SPRING - 55.30MM LONG X 10.06MM WIDE - CLEAR
    1 SPRING - 77.67MM LONG X 7.97MM WIDE - CLEAR
    1 CLIP - CLEAR
    2 PINS - 34.33MM LONG X 9.04MM WIDE - CLEAR
    2 SPRINGS - 13.96MM TALL X 16.05MM WIDE - CLEAR
    1 FLAT SPRING - 17.74MM TALL X 8.68MM THICK X 19.59MM WIDE - CLEAR
    DS E-BRAKE SHOE ASSMEBLY: DONE!!
    SAME AS ABOVE
    REAR AXLE STUBS: DONE
    2 NUTS - ACORN STYLE - 30MM - 30.04MM WIDE X 14.91MM THICK - CLEAR
    2 WASHERS - 25.99MM WIDE X 20.54MM HOLE X 4.23MM THICK - CLEAR
    FRONT SHOCKS: DONE!!
    2 BOLTS - CLW - 12MM - G4 - 19.57MM LONG X 14.17MM WIDE - CLEAR
    2 LINE CLIPS - 27.07MM WIDE X 27.40MM TALL - CLEAR
    POWER STEERING RACK ASSEMBLY: DONE!!
    2 NUTS - 22MM - 22.04MM WIDE X 11.02MM DEEP - CLEAR
    2 SPRING HOSE CLAMPS - 17.36MM WIDE X 10.20MM DEEP - CLEAR
    FRONT OUTER TIE RODS: DONE
    2 CASTLE NUTS - 17MM - 16.90MM WIDE X 8.13MM DEEP - CLEAR
    POWER STEERING RACK ASSEMBLY 2: DONE!!
    1 FITTING - 50.20MM LONG X 23.95MM WIDE - CLEAR
    1 BANJO BOLT - FLANGE - G7 - 25.90MM LONG X 20.53MM WIDE - CLEAR
    FRONT EXHAUST HANGER: DONE!!
    2 BOLTS - CLW - G4 - 12MM - 21.68MM LONG X 14.13MM WIDE - CLEAR
    FRONT-MOST SUBFRAME BRACE: DONE
    2 NUTS - FLANGE - 17MM - 23.56MM WIDE X 13.12MM DEEP - CLEAR
    2 WASHER PLATES - 61.26MM WIDE X 12.20MM HOLE X 5.01MM DEEP - CLEAR
    REAR TOW HOOKS: DONE
    6 BOLTS - CW/LW - G7 - 14MM - 32.25MM LONG X 21.68MM WIDE - CLEAR
    DRIVESHAFT ASSEMBLY: DONE!!
    6 BOLTS - ALLEN - vH7 - 67MM LONG X 13.36MM WIDE - CLEAR
    6 NUTS - 12MM - 11.97MM WIDE X 6.61MM DEEP - CLEAR
    6 LOCK WASHERS - 15.43MM WIDE X 8.53MM HOLE X 2.70MM THICK - CLEAR
    2 BUSHING INSERTS - 24MM WIDE X 10.81MM HOLE X 18.09MM TALL - CLEAR
    2 BUSHING INSERTS - 24.23MM WIDE X 10.62MM HOLE X 22.72MM TALL - CLEAR
    3 CRESENT MOON-SHAPED PLATES - BLACK
    EXHAUST 1:
    3 BOLTS - CW/LW - G4 - 12MM - 50.90MM LONG X 17.68MM WIDE - CLEAR
    6 BOLTS - CW/LW - G4 - 12MM - 45.70MM LONG X 17.62MM WIDE - CLEAR CANT FIND
    2 BOLTS - CLW - G4 - 12MM - 40.68MM LONG X 14.95MM WIDE - CLEAR CANT FIND
    13 BOLTS - CLW - G4 - 12MM - 21.63MM LONG X 13.95MM WIDE - CLEAR (ONLY 12 SHOWN IN PICTURE)
    3 BOLTS - CW/LW - NO GRADE - 12MM - 50.31MM LONG X 17.90MM WIDE - CLEAR
    1 BOLT - CW/LW - NO GRADE - 12MM - 45.26MM LONG X 17.63MM WIDE - CLEAR
    1 BOLT -CLW - NO GRADE - 12MM - 21.42MM LONG X 13.34MM WIDE - CLEAR
    EXHAUST 2: DONE
    7 BOLTS - CW/LW - NO GRADE - 10MM - 14MM LONG X 13.80MM WIDE - CLEAR
    1 BOLT - CLW - NO GRADE - 10MM - 24.50MM LONG X 10.42MM WIDE - CLEAR
    9 BUSHING CYLINDERS - 26.67MM LONG X 11.75MM WIDE X 8.50MM HOLE - CLEAR
    4 BUSHING CYLINDERS - 21.46MM LONG X 12.59MM WIDE - 8.60MM HOLE - CLEAR
    1 WASHER - 17.78MM WIDE X 8.47MM HOLE X 1.73MM THICK - CLEAR
    EXHAUST CLAMPS: CANT FIND
    2 CLAMPS
    REAR DIFF 2: DONE!!
    8 BOLTS - CW/LW - G7 - 14MM - 36.67MM LONG X 21.59MM WIDE - CLEAR
    DIFF BREATHER CAP - CLEAR
  13. #9
    Interior
    Interior photobucket album: Mitsubishi 3000gt Nuts And Bolts - Interior Photos by mudvaynedude122 | Photobucket
    headliner & visors: Done!!
    6 screws 22mm long x 10mm wide, phillips, black
    white wire harness bracket - dash bar: Done!!
    4 bolts - cw/lw - 21mm long x 10mm wide - g4 - 10mm - clear
    interior knee panel: Done!!
    2 bolts - cw/lw - 24.52mm long x 17.66mm wide - 10mm black
    2 bolts - cw/lw - 24.10mm long x 17.69mm wide - 10mm clear
    2 screws - 18.93mm long x 11.41mm wide - phillips - clear
    cargo cover brackets: Done!!
    2 philips machine screws - cw/lw - 21mm long x 10mm wide - black unsure of size
    2 small phillips screws - 11mm long x 6mm wide - black
    2 clips - black
    steering column: Done!!
    7 bolts - cw/lw - 33mm long x 24mm wide - g4 -12mm - clear
    ground disrto block: Done!!
    2 phillips screws 17mm long x 10mm wide - clear
    antenna bracket: Done!!
    2 phillips screws - cw/lw - 20mm long x 12mm wide - clear
    2 nuts - 10mm wide x 4mm deep - 10mm - clear
    2 rubber bushings with threaded ends - 38mm long - black (contains rubber)
    2 small lock washers - 12mm wide - clear
    steering column cover: Done!!
    2 long phillips screws - 36mm long x 10mm wide - clear
    2 phillips screws - 20mm long x 10mm wide - clear
    ds front seat: Done!!
    2 huge bolts - g7 - 14mm - cw/lw - 40mm long x 20mm wide - black (bake)
    2 nuts - spinning washer - 14mm - 22mm wide x 11mm deep - black (bake)
    steering wheel: Done!
    1 nut - 19mm wide x 10mm deep 17mm - clear (bake)
    1 lock washer - 20mm wide - clear (bake)
    ps sail panel / ps quarter panel: Done!!
    1 machine screw - cw/lw - 21mm long x 12 mm wide - phillips - black
    1 machine screw - flange - 19mm long x 13mm wide - phillips - clear
    1 interior clip - black
    1 screw - cw - 15mm long x 10mm wide - phillips - clear
    1 screw - 14mm long x 10mm wide - phillips - clear
    1 screw - 27mm long x 10mm wide - phillips - black
    4 screws - 30mm long x 12mm wide - phillips - black
    upper (finished) center console: Done!!
    9 screws - 20mm long x 10mm wide - phillips - clear
    1 screw - 14mm long x 10mm wie - phillips - clear
    ac controls: Done!!
    3 screws - 20mm long x 10mm wide - phillips - clear
    ps airbag: (need 2 screws/bolts) done!!
    1 bolt - cw/lw - 21mm long x 18mm wide - g4 - 10mm - clear
    1 bolt - cw/lw - 21mm long x 12mm wide - g4 - 10mm - clear
    dash: Done!!
    6 bolts - cw/lw - g4 - 10mm - 21mm long x 18mm wide - clear
    1 screw - 20mm long x 10mm wide - phillips - clear
    1 bolt - g4 - 10mm - 25mm long x 18mm wide - black
    shifter bushings: Done!!
    4 shifter bushing inserts - clear
    glovebox - incomplete- done!!
    2 bolts - cw/lw - 20mm long x 10mm wide - phillips - clear
    2 screws - 15mm long x 10mm wide - phillips - clear
    3 screws - 30mm long x 19mm wide - phillips - black
    steering column bracket:
    5 bolts - cw/lw - g4 - 12mm - 25mm long x 20mm wide - clear cant find 5
    hatch / trunk release trim: Done!!
    2 screws - 16mm long x 10mm wide - phillips - black
    1 screw - 15mm long x 9mm wide - phillips - black
    clutch pedal assembly: Done!!
    2 flange nuts - 12mm - 20mm wide x 9mm deep - clear
    1 bolt - cw/lw - g4 -12mm - 25mm long x 18mm wide - clear
    interior 3-relay box: Done!!
    2 screws - 20mm long x 10mm wide - phillips - clear
    rear hatch panel: Done!!
    4 screws - 20mm long x 10mm wide - phillips - black
    3 screws - 19mm long x 13mm wide - slight flange - phillips - black
    1 screw - 15mm long x 10mm wide - phillips - black
    shifter assembly: Done!!
    4 bolts - cw/lw - 35mm long x 20mm wide - g4 - 12mm - clear
    ps front seat: Done!!
    2 bolts - cw/lw - g7 - 14mm - 36mm long x 20 mm wide - black (bake)
    2 nuts - spinning flange - 22m wide x 10mm deep - 14mm - black (bake)
    interior spring clips: Done!!
    19 clips - black
    ac ducts: Done!!
    ps sail panel & 1/4 panel (wrong, combine with other ds sail panel list for ds) done
    1 phillips bolt - 15mm long x 13mm wide - slight flange - black
    1 phillips screw - 15mm long x 12mm wide - clear
    1 phillips bolt - 18mm long x 11mm wide - slight flange - clear
    1 phillips screw - 15mm long x 10mm wide - coarse threads - black
    1 phillips screw - cw - 15mm long x 10mm wide - clear
    8 springs clips - black
    fuel pump access panel: Done!!
    4 screws - 20mm long x 17mm wide - phillips - clear
    center console bracket (u-shaped): Done
    2 bolts - cw/lw - 20mm long x 18mm wide - phillips - clear
    rear hatch panel (l-shaped brackets)(may be wrong size screws): Done!!
    2 screws - 14mm long x 11mm wide - phillips - clear
    interior fuse box bracket - to fusebox: Done!!
    1 nut - spinning flange - 10mm - 14mm wide x 6mm deep - black
    shifter cables - firewall & extra clips:
    2 bolts - cw/lw - g4 - 12mm - 26mm long x 18mm wide - clear
    2 clips - 25mm wide x 33mm tall - clear cant find 1
    ds tall center console bracket: Done!!
    2 bolts - cw/lw - g4 - 10mm - 20mm long x13mm wide - clear
    2 bolts - cw/lw - phillips - 19mm long x 12mm wide - clear
    2 screws - phillips - 18mm long x 11.5mm wide - clear
    1 screw - phillips - 19mm long x 10mm wide - clear
    ps tall center console bracket: Done!!
    1 screw - phillips - 18mm long x 11.5mm wide - clear
    shifter: Done!!
    1 bolt - g7 - 14mm - 107mm long x 14mm wide - clear
    2 nuts - 14mm - 14mm wide x 8mm deep - clear
    1 nut - 12mm - 12mm wide x 6mm deep - clear
    2 lock washers - 18.16mm wide x 2.61mm thick - clear
    1 lock washer - 14.85mm wide x 2.09mm thick - clear
    1 washer - 25.86mm wide x 10.47mm hole - 1.58mm thick - clear
    1 washer - 21.85mm wide x 10.43mm hole x 2.28mm thick - clear
    1 washer 20.12mm wide x 13.41mm hole x 1.24mm thick - clear
    1 spring washer - 21.10mm wide 13.63mm hole x .48mm thick - clear
    1 clip - 23.32mm wide x 1.03mm thick - clear
    1 spring - clear
    1 washer - 20.06mm wide - clear (still need to remove)
    cig lighter housing: Done!!
    1 housing
    ps center console bracket - long: Done!!
    2 bolts - phillips - cw/lw - 15mm long x 12mm wide - clear
    1 bolt - phillips - cw/lw - 19mm long x 12mm wide - clear
    ds center console bracket - long: Done!!
    2 bolts - phillips - cw/lw - 19mm long x 12mm wide - clear
    back seat strikers: Done!!
    4 bolts - cw/lw - g4 - 10mm - 23.76mm long x 12.79mm wide - black
    glovebox fork bracket: Done!!
    1 bolt - cw/lw - g4 - 10mm - 20mm long x 13mm wide - clear
    tall center console brackets - mounting: Done!!
    8 bolts - cw/lw - g4 - 10mm - 20mm long x 13mm wide - clear
    rear center console cubby bracket: Done!!
    2 bolts - cw/lw - g4 - 10mm - 20mm long x 13mm wide - clear
    srs computer: Done!!
    3 bolts - cw/lw - g"e" - 10mm - 20mm long x 13mm wide - clear
    4 bolts - cw/lw - g4 - 10mm - 20mm long x 13mm wide - clear
    4 screws - flange head - phillips - 9mm long x 10mm wide - clear
    front center console cubby bracket: Done!!
    shifter - mounting: Done
    4 bolts - cw/lw - g4 - 12mm - 35mm long x 22mm wide - clear
    shifter cable bracket: Done!!
    front center console carpets bracket: Done!!
    2 nuts - spinning flange - 12mm - 18mm wide x 8mm deep - clear
    center console u-bracket: Done!!
    2 bolts -cw/lw - g4 - 10mm - 20mm long x 13mm wide - clear
    visors - extra: Done!!
    5 screws - phillips - 21mm long x 9.5mm wide - black
    front center headliner brackets(dome light): Done!!
    2 screw - phillips - 16.42mm long x 9.94mm wide - black
    blower motor - mounting: Done!!
    3 nuts - spinning flange - 12mm - 22mm wide x 8.68mm deep - clear
    ps footwell light bracket: Done!!
    front seatbelts(check picture for assembly order): Done!!
    2 bolts - flange head - g"n" - 17mm - 53.68mm long x 24.52mm wide - clear
    2 bolts - flange head - g(h1/07) - 17mm - 43.53mm long x 24.26mm wide - clear
    2 washers - 40.06mm wide x 2.02mm deep x 11.65mm hole - black
    2 washers - 19.84mm wide x 1.97mm deep x 11.70mm hole - clear
    2 washers - 27.80mm wide x 2.28mm deep x 11.84mm hole - black
    2 lock washers - 19.88mm wide x 2.94mm deep x 11.69mm hole - clear
    2 washers (bushings) - 19.65mm wide x 7.39mm deep x 11.42mm hole - black
    2 washers (bushings) - 19.75mm wide x 4.97mm deep x 11.34mm hole - black
    2 washers (bushings) - 19.87mm wide x 3.28mm deep x 11.35mm hole - black
    2 washers (bushings) - 19.68mm wide x 4.15mm deep x 11.33mm hole - black
    3 plastic bushings (should be 4)
    rear seat belts(shared this bag with front seatbelt solenoids - 2 bolts) done!!
    4 bolts - clw - g7 - 17mm - 31.86mm long x 19.85mm wide - clear
    front seatbelt solenoids: Done
    2 bolts - clw - g7 - 17mm - 31.86mm long x 19.85mm wide - clear
    rear seat backs: Done!!
    3 bolts - cw/lw - g7 - 12mm - 30.20mm long x 21.54mm wide - black
    ds footwell light bracket: Done!!
    ps wiring harness protector: Done!!
    4 screws - phillips - 19mm long x 1mm wide - clear
    ps below door - wiring harness plastic:!!
    4 nuts - spinniing flange - 10mm - 14mm wide x 6mm deep - clear
    1 screw - phillips - 19.5mm long x 11.5mm wide - clear
    ds below door: Done!!
    4 screws - phillips - 15.5mm long x 11.5mm wide - clear
    4 nuts - flange - 10mm - 15mm wide x 6mm deep - clear
    heater / evaporator - mounting: Done!!
    2 bolts - cw/lw - g4 - 12mm - 30mm long x 21.5mm wide - clear
    5 nuts - spinning flange - 12mm - 22mm wide x 9mm deep - clear
    gas pedal: Done!!
    2 bolts - clw - g4 - 12mm - 25mm long x 14mm wide - clear
    1 spring - 59mm long x 19.6mm tall - clear
    1 spring - 50mm long x 13.79mm tall - clear
  14. #10
    Interior cont.
    DS DASH SUPPORT BAR - GREY: DONE!!
    2 BOLTS - CW/LW - G4 - 12MM - 25MM LONG X 22MM WIDE - CLEAR
    3 BOLTS - CW/LW - G4 - 12MM - 25MM LONG X 18MM WIDE - CLEAR
    2 BOLTS - CW/LW - G4 - 10MM - 20MM LONG X 13MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 18.5MM LONG X 11.3MM WIDE - BLACK
    FAKE PEDAL: DONE!!
    2 NUTS - SPINNING FLANGE - 10MM - 14MM WIDE X 7MM DEEP - BLACK
    KNEE PANEL BRACKETS: DONE!!
    HATCH SIDE BRACES - T-SHAPED: DONE!!
    2 SCREWS - CW/LW - PHILLIPS - 19MM LONG X 12MM WIDE - BLACK
    4 SCREWS - PHILLIPS - 15MM LONG X 11MM WIDE - CLEAR
    HEATER CORE:
    2 SCREWS - PHILLIPS - BUTTON HEAD - 18.74MM LONG X 7.99MM WIDE - CLEAR
    3 SCREWS - PHILLIPS - BUTTON HEAD - 18.55MM LONG X 7.98MM WIDE - CLEAR CANT FIND 1
    6 SCREWS - PHILLIPS - 14.80MM LONG X 8.77MM WIDE - CLEAR
    3 SCREWS - PHILLIPS - 16.80MM LONG X 8.78MM WIDE - CLEAR
    3 SCREWS - PHILLIPS - 15.32MM LONG X 11.44MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 7MM - 19.09MM LONG X 7.00MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - CLW - 9.50MM LONG X 5.30MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 9.98MM LONG X 8.00MM WIDE - CLEAR
    9 CLIPS - CLEAR
    1 CLIP - CLEAR
    1 CLIP - CLEAR
    1 SHAFT - CLEAR
    1 LINKAGE - CLEAR
    BLOWER MOTOR ASSEMBLY: DONE!!
    3 SCREWS - TORX BIT HEAD - 8MM - 18.69MM LONG X 7.8 4MM WIDE - CLEAR
    4 SCREWS - PHILLIPS - 18.59MM LONG X 8.15MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 12.6MM LONG X 8.09MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 9.88MM LONG X 8.09MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 15MM LONG X 8.54MM WIDE - CLEAR
    1 HOSE CLAMP - 15.04MM WIDE X 6MM DEEP - CLEAR
    1 CLIP - 24.81MM LONG X 7.04MM DEEP - CLEAR
    4 SCREWS - CLW - PHILLIPS - 9.99MM LONG X 5.31MM WIDE - CLEAR
    1 LINKAGE - CLEAR
    1 SHAFT - CLEAR
    1 SHAFT - CLEAR
    1 SCREW - PHILLIPS - 18.32MM LONG X 8.22MM WIDE - CLEAR
    EVAPORATOR ASSEMBLY: DONE!!!!
    1 BOLT - CW/LW - G7 - 10MM - 34MM LONG X 13MM WIDE - CLEAR
    1 STUD - 43.96MM LONG X 7.93MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 13.05MM LONG X 11.66MM WIDE - CLEAR
    7 CLIPS- 21.54MM LONG X 9.97MM DEEP X 8.38MM TALL - CLEAR
    AIR DUCT MOUNTING CLIP: DONE!!
    3 CLIPS - 19.55MM TALL X 12.82MM DEEP - CLEAR
    DOOR PANEL - MOUNTING: DONE!!
    6 SCREWS - FLANGE HEAD - PHILLIPS - 18.58MM LONG X 11.79MM WIDE - BLACK
    4 SCREWS - DOME HEAD - PHILLIPS - 20.66MM LONG X 7.68MM WIDE - BLACK
    4 SCREWS - DOME HEAD - PHILLIPS - 20.13MM LONG X 6.61MM WIDE - BLACK
    2 SCREWS - DOME HEAD - PHILLIPS - 12.49MM LONG X 7.62MM WIDE - BLACK
    2 SCREWS - PHILLIPS - 12.49MM LONG X 7.62MM WIDE - BLACK
    4 SCREWS - PHILLIPS - 16.29MM LONG X 6.65MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 15.07MM LONG X 11.47MM WIDE - BLACK
    DOOR SPEAKERS: DONE!!
    8 SCREWS - PHILLIPS - 15.40MM LONG X 11.25MM WIDE - CLEAR
    INTERIOR DOOR HANDLES: DONE!!
    4 SCREWS - PHILLIPS - 15.89MM LONG X 13.52MM WIDE - CLEAR
    DASH BAR - MIDDLE - POINTS DOWN & DASH BAR - DS - POINTS UP: DONE!!
    2 BOTLS - CW/LW - G4 - 10MM - 20MM LONG X 13MM WIDE - CLEAR
    STEERING COLUMN - (EXTRAS?): DONE!!
    2 BOLTS - CW/LW - G4 - 12MM - 30.48MM LONG X 21.53MM WIDE - CLEAR
    2 BOLTS - CW/LW - G4 - 12MM - 25.32MM LONG X 21.62MM WIDE - CLEAR
    1 BOLT - CW/LW - G4 - 12MM - 25.35MM LONG X 17.63MM DEEP - CLEAR
    2 BOLTS - CW/LW - G4 - 12MM - 35.36MM LONG X 21.59MM WIDE - CLEAR
    PEDAL AREA: DONE!!
    3 BOLTS - CW/LW - G4 - 12MM - 25.38MM LONG X 17.6MM WIDE - CLEAR
    1 BOLT - CW/LW - G4 - 12MM - 25.25MM LONG X 21.59MM WIDE - CLEAR
    DS FOOTWELL AREA: DONE!!
    DS FOOTWELL BRACKET: DONE!!
    PS FOOTWELL AREA: DONE!!
    3 BOLTS - CW/LW - G4 - 10MM - 20MM LONG X 13MM WIDE - CLEAR (1 IS WIRING HARNESS SUPPORT - LITTLE WHITE PLASTIC CLIP)
    1 BOLT - CW/LW - G4 - 10MM - 24.13MM LONG X 12.78MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 18.98MM LONG X 11.33MM WIDE - BLACK
    FLOOR CROSS BRACE - GROUNDS: DONE!!
    2 SCREWS - PHILLIPS - 19.58MM LONG X 11.45MM WIDE - CLEAR
    PS QUARTER PANEL AREA: DONE!!
    1 SCREW - PHILLIPS - 12.15MM LONG X 11.43MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 15.08MM LONG X 11.34MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 19.58MM LONG X 11.43MM WIDE - CLEAR
    DS QUARTER PANEL AREA: DONE!!
    1 BOLT - CW/LW - PHILLIPS - 18.60MM LONG X 11.84MM WIDE - CLEAR
    1 BOLT - CW/LW - PHILLIPS - 14.86MM LONG X 11.74MM WIDE - CLEAR
    1 SCREW - PHILLIPS - 15.10MM LONG X 11.27MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 12.88MM LONG X 11.41MM WIDE - CLEAR (ADDED 1 AFTER PIC)
    STEERING WHEEL ASSEMBLY: DONE!!
    9 BOLTS - CW/LW - PHILLIPS - 14.79MM LONG X 11.74MM WIDE - CLEAR
    4 SCREWS - PHILLIPS - 18.66MM LONG X 6.71MM WIDE - CLEAR
    DASH: DONE!!
    17 SCREWS - PHILLIPS - 19.18MM LONG X 11.30MM WIDE - CLEAR
    30 SCREWS - PHILLIPS - 15.27MM LONG X 11.43MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 14.67MM LONG X 9.21MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 16.11MM LONG X 9.72MM WIDE - BLACK
    3 SCREWS - PHILLIPS - 23.02MM LONG X 11.43MM WIDE - CLEAR
    4 CLIPS - 14.91MM LONG X 14.35MM WIDE X 9.15MM TALL - CLEAR
    7 CLIPS - 17.93MM TALL X 11.49MM WIDE - CLEAR
    DASH VENTS: DONE!!
    6 SCREWS - PHILLIPS - 14.73MM LONG X 9.18MM WIDE - CLEAR
    SPEEDO BEZEL: DONE!!
    4 SCREWS - PHILLIPS- 19.29MM LONG X 11.46MM WIDE - CLEAR
    2 SCREWS - PHILLIPS - 12.35MM LONG X 8.19MM WIDE - CLEAR
    2 CLIPS - 20.07MM LONG X 10.02MM DEEP X 14.86MM WIDE - CLEAR
    REAR VIEW MIRROR: DONE!!
    1 SCREW - PHILLIPS - 11.71MM LONG X 8.04MM WIDE - BLACK
    REMOVABLE DASH PIECES: DONE!!
    2 SCREWS - PHILLIPS - 10.64MM LONG X 8.10MM WIDE - CLEAR
    2 CLIPS - CLEAR
    CHROME A-PILLAR FRAMES: DONE!!
    24 SCREWS - PHILLIPS - 15.37MM LONG X 11.30MM WIDE - CLEAR
    HATCH - UNDER LOCK: DONE!!
    1 SCREW - PHILLIPS - 15.40MM LONG X 11.38MM WIDE - CLEAR
    CARGO COVER HOOKS: DONE!!
    2 BOLTS - PHILLIPS - CONE HEAD - 19.65MM LONG X 11.67MM WIDE - BLACK
    HATCH RUBBER STOPPERS: DONE!!
    4 BOLTS - CW - G4 - 10MM - 19.97MM LONG X 12.98MM WIDE - BLACK
    STEERING COLUMN - SHAFT & PLATE: DONE!!
    4 BOLTS - CW/LW - G4 - 10MM - 29.22MM LONG X 17.70MM WIDE - CLEAR
    1 BOLT - CLW - G7 - 12MM - 35.68MM LONG X 15.00MM WIDE - CLEAR
    4 BOLTS - CW/LW - G4 - 10MM - 18.22MM LONG X 12.82MM WIDE - CLEAR
    2 SPRINGS - 48.71MM LONG X 17.59MM WIDE - CLEAR
    E-BRAKE HANDLE: DONE!!
    4 BOLTS - CLW - G4 - 12MM - 25.46MM LONG X 14.15MM WIDE - CLEAR
    1 PIN - 22.09MM LONG X 14.11MM WIDE - CLEAR
    DOOR LEVERS: DONE!!
    4 NUTS - SPINNING FLANGE - 10MM - 13.97MM WIDE X 6.23MM DEEP - CLEAR
    E-BRAKE HANDLE ASSEMBLY: DONE!
    1 BOLT - PHILLIPS - CLW - 12.87MM LONG X 8.71MM WIDE - CLEAR
    E-BRAKE LINKAGE "T": DONE!!
    1 ROD - CLEAR
    1 CLIP - CLEAR
    1 THREADED SECTION - 10MM - 19.40MM LONG X 9.89MM WIDE - CLEAR
    1 ROUND CYLINDER - 20.76MM LONG X 12.78MM WIDE - CLEAR
