Would it be possible to make an engine moderately efficient, and allowing it to use all the fuels that are available, gas, e85, diesel, etc, if you controlled how much air was sucked in to be compressed?
So, take a diesel and have a variable valve set up to open, or close at the right times to account for volume in a cyl.
Not that I am right, but I think it could work because if you only allow a certain amount in it would only be able to compress so much or little to essentially have the right compression.
Coupled with electronic injectors(or electrically controlled) you could supply the right amount of fuel for the proper air charge too.
The things I do know and have read are diesels use glow plugs, direct injection, and have high compression. Gasoline is low compression, have either direct, or port injection, and use spark plugs. So it would have to be a dual plug setup if it were to have a chance.
This is just a complete theoretical thing. I'm not concerned with money or how complex it may be to make, just an open discussion. So any and all constructive criticism is good and allowed.
And if I put this is the wrong forum and someone is able to move it to more appropriate forum, thanks. And sorry.
