Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: DogBox on eBay!!
    Good to hear, mine looks good but a bit f-ed up. I almost called you the other day. I probably will be calling you in the next day or two.
    You know the number
    Not to chuck a spanner in the works but I rebuild bike engines for a living and the 1000cc gear clusters look to have more dog engagement than that (could be how the pictures were took?.).
    850HP NASCAR engines go through a t10 gear cluster with half the dog teeth number. The number of dog teeth doesn't determine the torque rating but it does determine backlash distance which determines the engagement window you have. More teeth = less distance between the engagement faces = narrower window which means the more precise you need to be to have a clean engagement. In a bike or any vehicle with a drum actuation and close ratios you can get away with the narrow window without getting locked out. The T10/t101 and Jerico derivatives have huge amounts of backlash which is very interesting to try and drive at low speeds, upside is huge dogs is strong dogs, you are not going to sheer one off.
