idle & cruise logs.zip
Jester's plug n' play, 1st gen fed spec TT.
1000cc denso injectors
482 montero maf
I'm trying to figure out what's going on with my car. Injector scale/latency adjustment got it to idle okay, a little rich, 02's not cycling, but running good. I figured I'd take it out for a drive and let the low/mid trims adjust. It started off driving smooth for about 1/8 mile, then it slowly leaned out completely. I'd give it more throttle and it would just rapidly pop (backfire), but not loud. I had to drive very slowly and light on the throttle to get back home. I gave a couple hard throttle pushes to get it out of closed loop and it seemed to straighten out, however there was absolutely no power. Looking at my logs, it appears that something is wrong with my narrowband 02's. The numbers are everywhere. Can someone take a look at my logs and see if something jumps out at them as abnormal? I'm going to double check ignition and valve timing and check for boost leaks, compression test and check spark plugs this weekend. Anything else I should try or check?
-Mike
