Results 1 to 4 of 4
Thread: reading 1999 ecu
    Jun 2013
    reading 1999 ecu
    How do I Read the image on my 1999 euro ECU and save it before writing Chrome onto it.
    I would like to see what is on the original and save the file just in case I make an error
    can I just plug my existing harness onto the 99 ecu
    or do I have to have flash cable attached to the diagnostic port OBD1,if so what would the pin number be to connect to
    I do not want to reflash as yet just to read
    many thanks Martin
    Apr 2011
    Ecuflash.read from ecu. Then once its all populated from the read go to save rom as
    Proud owner of
    2nd gen Magna TS 1995
    Twin Turbo 6G72 DOHC,
    FWD 5 speed, Jesters Chrome ECU V2,
    Custom 3" Exhaust, Magnaflow High flow Cat & Muffler, Redback resonator,
    CX Racing FMIC kit, EVO 9 BOV, AEM uEGO wideband,
    Turbosmart Gauge, Tactrix 3 port boost solenoid, K&N FIPK
    MSD 8.5 ignition leads, Apexi 3 bar MAP sensor,
    TJ Magna Clutch Master Cyl, 3SX S/S braided fuel line,
    Montero 482 MAF, Aeromotive 340l , 3SX fuel rail loop,
    VAC delete, Fuel pump hotwire and relay bypass
    GTO hubs and rotors, 4 pot calipers
    Tein Flex adjustable coilovers (tuned for +castor)
    Ride build page on FB
    My Vehicle Garage
    I already saved an image of your 1999 Euro ECU. However, if you like to save a copy do this:
    1 - Plug in Tactrix into OBD2 socket
    2 - Plug in flash wire/connector (stereo type plug) into Tactrix.
    3 - Plug in Tactrix USB cable to notebook
    4 - Turn ignition to ACC
    5 - Run ECUflash software, read from ECU, and save.
    Your conversion harness will include an OBD2 connector and flash wire stereo plug.
    Jun 2013
    hello antero
    therein the problem lies Plug in Tactrix into OBD2 socket
    got no obd2 socket to check. If you can can i have a look at the file you have saved
    cheers martin
