Results 1 to 3 of 3
Thread: euro 99 ecu
    Jun 2013
    euro 99 ecu
    has anybody been able to get the wiring sorted for one of these to work on a 1991 jdm gto so that it can work with the chrome software
    I have been offered by blackstealth to make a harness but wondered if there was other options to make it pnp with tactrics
    thank you all for the patience
    Apr 2011
    Yep!
    I have a 91 GTO motor that's using Chrome ECU.
    The stock GTO ecu doesn't support obd2 so a chrome ecu is required to flash tune.
    The obd1-obd2 adaptor is also required to use with a tactrix open port 2 cable and evoscan and ecuflash.
    www.chromecu.org has the details. As for GTO it covers 91-97 models.
    Proud owner of
    2nd gen Magna TS 1995
    Twin Turbo 6G72 DOHC,
    FWD 5 speed, Jesters Chrome ECU V2,
    Custom 3" Exhaust, Magnaflow High flow Cat & Muffler, Redback resonator,
    CX Racing FMIC kit, EVO 9 BOV, AEM uEGO wideband,
    Turbosmart Gauge, Tactrix 3 port boost solenoid, K&N FIPK
    MSD 8.5 ignition leads, Apexi 3 bar MAP sensor,
    TJ Magna Clutch Master Cyl, 3SX S/S braided fuel line,
    Montero 482 MAF, Aeromotive 340l , 3SX fuel rail loop,
    VAC delete, Fuel pump hotwire and relay bypass
    GTO hubs and rotors, 4 pot calipers
    Tein Flex adjustable coilovers (tuned for +castor)
    Ride build page on FB
    My Vehicle Garage
    Apr 2011
    I just read some of your other threads and what I posted probably won't be what your after considering you already have a 99 ecu for your 91 model GTO.
