Looking at getting some XXR 530s. Not 100% sure they will fit (17x8.25 +35mm offset). If someone knows they will fit then let me know.
The max tire size I would ever run is probably 255. My tires are 245/45/17 anyway. I rarely track my car, its a daily driver/street/occasional autoX car. I found that I have 2 out of round rims and Im going to retire the "mustang" rims.
Unsure on the 17's and 1st gen brakes.
I believe the AMR 18's work unless you are dead set on 17's.
Ive got XXR 530s in 17x9.75 with a +25 offset. they clear the front 1g brakes with a small 3mm spacer.
