Results 1 to 10 of 24
Thread: Supra content: 730WHP dyno and street pulls
    Hit the dyno a few weeks back to do some test pulls with the new Gforce ECU w/ 8000RPM rev-limit and stock timing map (old ECU had a 7400RPM limiter and very aggressive timing) on 'mid-boost' due to being octane-limited (Sunoco 110).
    729WHP dyno pull -- 27psi:
    In-car view:
    716WHP dyno in-car view -- 26.5psi:
    Street pulls after the dyno -- dead hooks 1st gear on 19" R888's...!
    This was going to be my 1/2 mile setup (with more boost), but decided to step up to a larger turbine and exhaust housing, which is going on this weekend. New dyno #'s soon!
    Formerly:
    Here is a few video from a few months back at 680ish WHP, since I don't think I previously posted it:
    Go to "Fusefuel" and get 116 unleaded. Actual is 117.8, but they call it 116.
    Keeps knock away like you would not believe.
    Mods
    2ND place Autocross NG09
    Crimson Jihad Not Verified
    Amazing! Your videos never disappoint. Thanks for sharing!
    CAUTION: Over Boosting May Cause Accidental Orgasm.
    1993 Mitsubishi 3000gt VR-4
    Stuper Moderator
    January 2003
    Awesome! Man, what a beautiful sound...
    Douches
    Aye - good gawd, Abram.
    Quote Originally Posted by GTwizard View Post
    Never heard of it before, so I looked into it. Not surprising that the MON of their "116" is only 108. Evidently you still can't get a good MON without lead..! RON is a worthless measure and with the large delta between the RON and MON, it skew's the RM/2 to make it look a lot more knock resistant than it is. For reference, VP 110 is MON 107; Sunoco 110 (which I get at the pump locally) is MON 106. I can make about 700WHP on Sunoco 110 before it starts to pepper the plugs. C16 on the other hand is MON 117 which tells you how well it truly performs knock-deterrent wise; as such, that's what I will stick with on KILL mode.
    That said, I do believe 108 is the highest unleaded MON fuel I've come across. It would be a good 'street' fuel, but I bet they're pretty proud of it ($$$).
  8. The Following User Says Thank You to HellBringer For This Useful Post:
  9. #8
    Quote Originally Posted by Disrupter View Post
    Thanks, fellas! It's an absolute blast to drive and with it dead hooking 1st gear it's untouchable on the street..!
  10. #9
    Always love seeing videos of your Supra. Must just be scary fast if all that power hooks up.
  11. #10
    Low & Slow verified
    Fortson, GA
    Nice!!!! C16 is pretty hard to beat when it comes to high octane fuel.
    Jeff
