If I remove the whole ecs and wiring, what happens to my shock settings...if "medium" I'd be ecstatic.
Does the techworks actually do the additional functionality of the ecs with speed/tps/g/steering etc and do active changes?
You pull the ecs after you've selected what you want mode you want to be left in. With a stock setup, only tour or sport.
2013 January Car of the Month - All 3s
2011 November Car of the Month - Interior
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
Uncut 3000GT keys for sale! Various colors!
No. it only allows you to set the mode soft/medium/hard and has a full built in test mode that tests each strut individually.
I believe that the stock one only uses the G , Steering and TPS sensor to make adjustments. G sensor is a single axis that will adjust the strut based on take-off to stop squatting and hard braking to stop nose dive. Steering combined with TPS is used for roll control. I know it was discussed that using a single dual axis G-sensor would be much easier then using the signals from three different sensors. The stock adjustments are only done in Tour mode, Sport mode locks the struts into Hard mode and does no adjustments. I would rather have the ability to just set a specific mode then rely on the system setting various modes based on inputs as their will be a delay on setting the different modes as you drive. it also adds in multiple points of failure for the system itself along with the known issues of it interfering with ECU signals.
Does the techworks have a dual axis g sensor? Or was that just discussion?
Just a discussion.
It's probably a multi axis G sensor, because it also sends heave information to the ECS computer. The ECS computer also uses speed information.
The factors for switching modes is outlined in the TIM.
Gonzo's correct - techworks is a pure manual controller - no sensor inputs . The only inputs it does take are feeds from the signal switches inside the struts and the ECS switch (Oem or rotary add-on.)
p.s
Also Gonzo - as long as your on the thread- I have a new firmware update for your controller ( & anybody else who has a unit). I'll PM you the details but basically it's better diagnostics.
Favorite Car - A 1998 RED VR4 , pretty much stock except: Suspension: '94 ECS Struts Retrofit w/ Tein H-Techs controlled by TechWorks ECS Suspension Controller
www.renegadetechworks.com Open Source 3000gt ECS Retrofit & Replacement Controllers
