now that you mention it although I'm running an evo maf the sensor is not the same one that I had previously..not the same physical unit. Not sure if that may affect readings. Both mafs were/are OEM stock.
I posted my fuel map and datalogs on page 2 for you to see. 2byte airflow went up but overall peak load numbers fell slightly. Not sure how much temperature will affect airflow data.
