1995 $ 4200
1995 Pearl White 3000GT VR4, black interior, 72k miles, $4200. I bought this car when I was in college, intending on making it a track car and just never had the time or motivation to finish it. It runs and drives, but not well because of the following:
Cruise control has been removed and throttle cable rerouted to account for this, but the throttle body spring is loose and closes slowly, so when you rev it up, it takes a few seconds to slowly come down
Power steering pump is not working. I have a replacement, just have not installed it.
There is a leak on the fuel pump bulkhead when the car is running, I think it just needs a new gasket, but the whole thing is pretty rusty and should probably be replaced.
I removed the air conditioning system, the whole thing is intact and could be put back in if desired, but I won't be doing so.
There is no exhaust currently on the car.
Needs some body work. The front bumper has a gash in it and could probably use replacing. One of the rear corner pieces is a replacement part and a slightly different color. The CF hood needs to be adjusted to fit properly. The front right quarter panel and side skirts were taken off to do engine work and need to be properly fitted back on.
Other than that, this would make a great platform for someone looking to build a track car. It has low miles, fresh 60k engine service, the whole long block is clean and all maintenance parts are new. It has 3SX polyurethane motor mounts, a Koyo radiator, aluminum radiator pipes, MSD plug wires, Walbro fuel pump, RPS stage 3 clutch and aluminum flywheel, carbon fiber hood, and probably a few more things that I've forgotten.
It can be started and driven onto a trailer, but should not be driven more than that in its current state.
