Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: Wheels please?
  1. #31
    The Panda Not Verified
    Washougal WA/Portland OR
    Isn't that a 19 offset?
  2. #32
    he says backspacing is 6". if my math is correct, on a 9.5" rim, +0 offset = 4.75" backspacing (6"- 4.75" = 1.25"). Since 25.4mm = 1 inch, (25.4*1.25) = 31.75mm, or roughly 32mm.
    I can't really find any confirmation on fitment, but I do know this guy ran some:
    http://www.3swiki.org/BlkTT_%28Mark_Huang%29
    I don't know what size, offset, etc. I figure if they fit on 1g brakes, they should fit on 2g, since it IS an 18" wheel.
  3. #33
    and apparently, overnight, they sold.
    fml.
  4. #34
    Ipd I don't want you to buy the wrong offset again so here is the backspace to offset formula. First take the overall rim width including outer lip (usually add + 1" to the 9.5 = 10.5 for the advans), then divide by 2,(5.25) then subtract that number from the measured backspace (in your case 6"- 5.25", then convert to metric by multiplying by 25.4.
    10.5 /2 =5.25 Then 6 - 5.25= .75 Then *25.4= 19.05mm
  5. #35
    For future reference this chart makes it easy. And Thadd don't rush, take your time and get the wheels you really want and never worry about it again.
  6. #36
    Here is a set of black 42 offset super advans for more than you want to spend, but theses would be my choice for fitment to avoid an inch out rubber sticking out in the front.
    NWP4LIFE: jdm rims .........
    edit: just noticed that post was a couple years old.
  7. #37
    damn those are sexy. too bad they're not 1/2" wider and a bit less offset...
  8. #38
    p.s.
    yeah, if it was still for sale...maybe. but i'd have to go back to 275's...for sure.
