That's too bad I kinda like those All-Star wheels ..
Support NG!
The hubs I got (iirc, from 3sx) were brand new when I did the 2g brake conversion. I never had any issues with these wheels--even with the stock suspension--when I was running 275's without spacers. The 2g conversion forced me to use a spacer for brake clearance. Due to the premature failure/wear, I'm inclined to believe it's the ~12mm spacers up front. Even with the spacers, I had to shave the calipers a tad in order to fit. Rears fit without spacers, but I also had to shave slightly.
You're correct in referencing the clearance to the strut tower/perch/suspension bits. Offset is key for that. What I'm referring to, however, is not clerance around the suspension, but rather clearance around the brake caliper. With regards to the brake caliper clearance, a wheel with +60 offset and a wheel with -40 offset will fit THE EXACT SAME with regards to JUST the caliper...provided the spoke design is identical. I learned this lesson the hard way with this set of wheels, which--by rights--should fit because the offset is fine. 22mm on 10" wide is LESS inner depth than 45mm on 8.5" wide. 32mm offset on 9.5" should be equal to stock inner depth. (And incidentally, 9.5"-10.5" is the recommend width for 285/35r18). So 9.5" gives me the option to run 285 or 275 in the future without the "stretched" look my old 275's had.
1010TIRES.COM - Wheel Offset Calculator
Tire Rack said no-go on the Motegi's.
Miro 563 18x9 5 5x114 3 34 Squared Matt Black Acura TL TSX Civic RSX Accord 398 | eBay
I'm looking at these too.
P.S.
I really do NOT want to have to get new wheels, as I really like my GT-C's. And it's almost certainly cheaper to buy a BBK for the front than new wheels+tires. I'm trying to locate a fitment template for bbk right now.
What I still cannot figure out is how everyone else that has GT-C's on their VR4 (face 2 design) doesn't have this issue. Maybe the spoke design on 10" is THAT radically different.
Opinion time:
LOL at the quality of the first wheel listed compared to the rest...
Why are you set on not buying tires? How old are the 285s you have right now? You may want to reconsider your overall approach here... do you really need a 285 tire? Size for size's sake is silly if you're running a crappy and/or old tire. Also, there's pretty much no way to fit that kind of tire under a 3/S front fender.
Why don't you look for a couple of Face 1 GT-Cs? If you have time and patience to search I'd bet you'll be able to find some. It's possible you could swap the face of the Face1 to your 10'' wide barrel so you keep your wheel width while changing the pad height and spoke design to clear your 2G brakes. Pad height is your main issue here. I have never seen anyone run a Face 2 on the front of a TT brake equipped 3/S car.
1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
DR-650s and supporting, PST CFDS, Volk GT-Cs, Tein Flex, among other things
Feb. 06 3SI ROTM - Best AWD BRG 07 - 3rd Place 2G 07 3/S National Gathering - People's Choice BRG 08
BRG 2011 Total Package - NG11 Car Show 1st Place
2010 Space Gray E90 335i M-Sport 6MT - 400whp/450wtq
2002 Jet Black E53 X5 4.4i AWD - Bavarian Workhorse
I WISH someone would have told me to get face 1's when I bought them. But at that time, I don't even know if anyone was running them.
That's not a bad idea to try and swap parts, but good lord that's a needle in a haystack--and more $$$ than just getting a new set.
As to the quality/age of my tires? Minty.
Nope. You are forgetting the #1 contributor of 3S wheel fitment: Pad height. You keep assuming that the only way to change offset is by moving the barrel. Pad height is what spacers change, it's the distance of the mounting surface to the spokes, and it's not a normally published number. If a +20mm offset has the same face and lip, pad height was increased 20mm, which would give 20mm more brake clearance as well as 20mm more strut clearance.
I also don't think spacers killed your wheel bearings. Your Mexi-flush wheels do increase load on it, but Dan and Pete both run massive offsets and race on them with real boy tires and they don't have to replace wheel bearings left and right. Dan is running 305mm wide slicks and is putting more load than you can dream of on his bearings and for your wheels to have killed a bearing would mean he'd be replacing them weekly. The #1 killer of our wheel bearings is putting weight on them without axles in place. Near instant death.
[edit]: Rob beat me, lol.
Ah, I stand corrected. I was under the impression that pad height was static for a given spoke design, but i can see how that might not be the case.
I vote wheel and tire package. Get the tires close to flush and run a 265 for a tire on a 9' rim with a 35 offset. (I personally would do a 40 offset) good luck with your search.
Super Advan SA3R 18x9 5 5x114 S2000 Skyline Silvia Supra RX7 Civic FD2 DC5 S2000 | eBay
I think i may have just found a holy grail. Anyone know if these will fit? According to this:
http://www.tyresizecalculator.com/ty...ace-calculator
the backspacing should be ~32mm...which is PERFECT.
I'm with you on the fact that I really like the super advans.
