Results 11 to 20 of 38
Thread: Wheels please?
    August 2010
    Chicago
    Whats wrong with your GT-C's?
    34XXlbs..
    Well an 18x10+22 would generally have more clearance than a 18x9+30, no? Order one, see if it works. They are cheap.
    Incorrect. Offset has to do with clearance for the suspension (and in extreme cases, the wheel well). Spoke design determines fitment around the brake calipers. All wheels mount to the same hub, so the spoke design is key.
    My GT-C's do not work with 2g vr4 brakes...and in fact required spacers and shaving the calipers in order to fit. I originally ordered them with the explicit intent that they work with 2g vr4 brakes, but I did not actually complete the 2g brake conversion until a few years ago. I ran them fine on N/A brakes for years.
    P.S.
    cheap is relative. it's still several hundred that i might not be able to do anything with if it doesn't fit.
    I think the SSR looks the best......I don’t care if you want the advice or not
    it's just $500 more than some of the others. that...and since i'm 99% certain everyone here likes them...i'm inclined NOT to go that route on principle...
    I just wish I had options. That ages-old 3sdie list of wheels that fit---yeah, I'm pretty sure all of those are out of production now.
    I use Enkei PF01 18x9.5 35mm offset in brake dust color for my dry wheels. They do clear 2G brakes, 2G wide rotor brakes, Big Reds, and 355mm class brakes. They are also decently light and the lug holes are large enough to use real lugs.
    They also don't stick out like hellaflush kids love these days. I paid a good premium to not be hellaflush, and reduce my drag.
    Delaware
    What is your effective offset of your GT-C's now?
    You may be spending money on wheels when you dont really have to. The only way you're gonna fit a 10" wheel or w/e(10" is barely big enough to properly fit a 285) will probably put you nearly at the same effective offset you have now.
    Your wheel bearings may have just plain worn out or if what you have was fairly new they were of sub par quality even if OEM its not unheard of for OEM parts quality on older cars to be hit/miss.
    Jason
    The Panda Not Verified
    Washougal WA/Portland OR
    P.S.
    If I understand you correctly, You are wrong.
    You are correct Nate. As long as you have the same size tire and the tire is wider than the wheel. Isn't a 285 wider than a 10" wheel 11.2" to be exact.
    Offset is how far the mounting flange is off center!
    the quick math 285 divided by 2 is 142.5
    So on a 0 offset you have 142.5mm of tire on the inside of the mounting flange and 142.5 on the out side of the mounting flange.
    Now we know the larger the offset the closer the wheels are to the center of the car.
    18x9 +30 with a 142.5 from zero puts it at 112.5 on the outside and 172.5 on the inside
    18x10 +22 with a 142.5 from zero puts it at 122.5 on the outside and 164.5 on the inside (more clearance to the strut)
  8. #18
    He is correct in saying offset means nothing about brake clearance when selecting a wheel fitment......but he is forgetting that when talking about 2 of the same wheels with the same faces, offset tells all.
  9. The Following User Says Thank You to anyonebutme For This Useful Post:
  10. #19
    Well everyone here hates hella-flush so be a rebel and go that route also you big dork
  11. #20
    fyi stoptechs or similar have a little more clearance. It may make more sense upgrading your brakes than replacing really nice wheels.
