Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 66
Thread: Group buy retro-spec 3000gt side splitters
  1. #31
    The Panda Not Verified
    Washougal WA/Portland OR
    Speed tested?
  2. #32
    Never finishes any verified
    Wake Forest, NC
    My concern is the shape of the underside. that unfinished/concave underside will play havoc with the air passing under it and I don't think I'd trust it at high speeds. it really needs to be a smooth flat surface. Those downward rolled edges on the underside would generate lift and drag. Probably to the point at high speeds it would tear them right off of the self taping screws. That is all assumption though based off of the underside shape.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #33
    August 2010
    Chicago
    half the time 3/s cars are on jackstands...c'mon now...
    34XXlbs..
  4. #34
    Once I saw the shape of the underside I lost interesting these. With the "unfinished/concave underside" it will play havoc with the air passing underneath the car. These provide no function at all, only looks.
  5. #35
    Wake Forest, NC
    A flat piece of ABS black plastic cut out the same shape would be better for the airflow.
  6. The Following User Says Thank You to DrGonzo For This Useful Post:
  7. #36
    Or even a flat sheet of metal, the important thing is "FLAT"
  8. #37
    Not so sure it is as much of an issue as you are making it out to be.
    A speed test will tell the tale. (GoPro vid)
    It is also solved pretty easily by filling/sloping the leading, and trailing under-edge with filler, or spray foam. THe outside edge has no effect. Not something the end user should have to do granted, but can easily be done before shipment of the product.
  9. #38
    Also understand that if this is glassed in to fill the void you just threw your jacking ability out the window.
  10. #39
    Wake Forest, NC
    You can leave a small section out for the jacking points or make a removable plug to still use them.
    Mine were so bad from the previous owners, both side welds are all bent to shit all the way down the sides I had to pry a lot of it back as straight as I could to get the side skirts on. I use the front jack point under the bumper with my low-pro jack and the trailer hitch to raise the rear. One it is high enough on the 1st or 2nd notch of the jack stand the I use different points on the rear and front sub-frame.
  11. #40
    Delaware
    I've been to 150mph several times with mine on my FD which are only held on by 4 screws using existing screw holes since i wouldnt allow adding holes to my car and 3M 2 sided tape. They are still there.
    Oh and yes of course these are just cosmetics. No on here is fast enough of a driver for them to be a functional aero part.
    Jason
  12. The Following User Says Thank You to JasonY For This Useful Post:
