Has anyone ever installed heating pads to the stock seats? I am just curious as it looks pretty simple to do. I found this kit:
Amazon.com: Dorman 628-040 Universal Seat Heater Kit: Automotive
The 3000GT's sold here in Europe (in Sweden and Germany at least) all had heated seats. If you dig through ASA you might be able to lookup the part numbers for the stock heating pads and switch (mounted beneath the radio).
Here are the ones I've used. I put them in my Mazda and then put another set in my truck. They work great and are easy to install. I've never put them in the 3k though since I don't drive it much after it gets cold.
Universal 11" x 19" Carbon Fiber Heating Element Heated Seat Heater Kit
