Alright, so I'm looking for input from you e85 guys... I am going to switch to e85 (again) but this time, I'll be going with a different setup. I tried running E85 with a hotwired Walbro 255 and 750cc injectors and no AFPR. It wasnt bad at all, but then I switched back to gasoline after mistaking spark blowout for symptoms of not getting enough fuel. So now I'm about to put in an AEM E85 fuel pump (hotwired again) and I don't know if its good/bad to go back with the 750cc injectors or jump to some 1000cc. I run an ARC-2 and I'm wondering if 750's with a AFPR will work nicely or do i need to drop another $500 on my third set of injectors? Would I even need an AFPR with the 750cc/hotwired E85 pump/ARC-2 setup? How about with 1000's? Any advice is much appreciated!!![]()
