Can anyone help with a fuel gauge that is lying to me? It's telling me that I have nearly a full tank but I know I don't. When the car was on the road I would fill the tank to the brim and it would read until it got to half tank and then stick. The only way I knew that the car was getting low was because the fuel warning light came on even though the gauge was still reading half a tank. I pulled the sender unit out checked to see if it was sticking, it wasn't, did an ohms check and it was doing what it was supposed to be doing, checked the ground etc. etc. I put it back in, it worked once and then would only read 1/2 to full again. Any ideas 3S pro's? Thank you.
