Help! My MAF plug was cut off and now I need to know which color wires go to the MAF sensor. can some tell me which color wire goes to each terminal its a 93 vr4
The MAF sensor Wiring for a 91-93
1 Green With Yellow Stripe: 5V power for Baro Sensor (Pin 61 on 91-93 ECU)
2 Orange: Baro Singal to ECU (Pin 65 on 91-93 ECU)
3 Blue with Yellow Stripe: Airflow Signal to ECU(Pin 70 on 91-93 ECU)
4 Red: Power for Airflow sensor, (To Control Relay)
5 Black: Ground for IAT, Airflow and BARO signal (Pin 72 on 91-93 ECU)
6 Red with Blue Stripe: IAT signal going to ECU (Pin 52 on 91-93 ECU)
7 Red With White Stripe: Air Flow sensor Reset Signal (Pin 19 on 91-93 ECU)
8 Not used :
Credit to 3si wiki.
thanks your the best.
I have
the following wires
Green/Yellow
REd/white
orange
red / blue
black
blue/yellow
so perfect
