Results 1 to 10 of 26
Thread: Spyder Build
    Spyder Build
    Thought I would post my build just to get input and opinions, especially once I start reassembling. Build started when I pulled from a light pulled about 15PSI and heard a loud pop noise and the blowoff valve went off. So coasted to the gas station and the engine idled fine. So I pulled away car just seemed like it had as much power as a 4 Banger and wouldn't boost over 5psi. Compression test showed 90PSI in all cylinders and timing was dead on Except for front bank E-0, I-(-2). So after puling engine I saw the down pipe had more holes and cracks in it and had to be replaced. So I went ahead and unbolted the Catalytic converter and found this:
    So I'm pretty sure the engine was completely fine, in fact it was in excellent condition for 78k… original crosshatch, bearings were fantastic, and heads were great. So I went ahead and decided to do a full out build so I do not have to pull this engine for another 200K.
    My first build I'm aiming for 500WHP w/meth. Once I get bored at that power level I'll upgrade the heads and turbos.
    Underlined-Items still need to be purchased
    Build List:
    Engine:
    Wesco Piston w/.200 Upgrade
    Chrome Rods
    Clevite Bearings
    ARP Studs
    120k Kit
    Gasket upper and lower
    DR650 Turbos/Kinugawa 15PSI Wastegates
    DR STG 3 Heads
    DR Ported Lower Plenum
    Support:
    Dual Core FMIC
    Greddy FV BOV
    Hallman MBC
    TB rebuilt by April
    Cloned ECU
    482 EVO MAF
    Mishimoto Performance Radiator w/hoses
    Fuel:
    550CC Lucas Injectors
    Walbro 400 E85 Fuel Pump w/Hotwire
    Fuel Loop
    3SX Custom Fuel Kit
    Exhaust:
    GCTECH Manifolds/02 Housings
    Tanabe Touring CBE
    LC-2 Standalone
    3SX Downpipe w/Racepipe
    Misc:
    Tubular Front Crash Bar
    Aftermarket Boost Gauge, Oil PSI, Wideband, and Fuel PSI
    Light Weight Flywheel (Revert back to OEM per Chris from NP)
    SPEC Stg 4+ Clutch
    99 Lifters
    EGR Delete
    Krank Vents
    T-Case Bracket
    Solid Motor Mounts
    ABS Delete Kit
    AWS Delete
    Bell housing Brace
    Grounding Kit
    Current Status of Build: Transmission/TC is at shop getting general inspection and brace installed. Engine has been inspected and given the thumbs up and delivered everything to get bored/hones, balanced, and have flywheel 2-steped.
    Random Pics:
    First Purchased:
    After My first build 2 months prior to Incident:
    Right Before the Incident:
    Engine Pulled:
    In for the fun, and we need picsof the beast!
    That's some weird shit that happened.
    Gotta love Spyder builds.
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    ----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
    Updated Build list:
    Bought GC Tech Manifolds/02 Housings, 3SX DP w/Racepipe, STG 4+ Clutch. I also made a pretty significant purchase that will be a surprise :-), going for 500WHP on pump gas only.
    Oct 2011
    Sundsvall, Sweden
    Where did you buy the GC Tech Manifolds/02 Housings?
    Quote Originally Posted by Unlogic View Post
    I was pretty lucky. Guys posted it on for sale at 1AM and I just happen to be up early and was able to snag them.
    Oct 2011
    Sundsvall, Sweden
    You lucky bastard
    Update: Pictures:
    MMmmm my favorite view!
    Cool! spyder build! Look forward to seeing it go together. You plan on painting it?
