Results 1 to 10 of 30
Thread: UK/Euro '99 Flash ECU Fuel Trims using Evoscan
    Hi,
    I am running a Jap spec GTO TT, with the Euro/UK '99 Flash ECU fitted.
    It seems to work just fine, and I am currently running Evo560 injectors.
    Problem I have it the long term fuel trims are not visible in Evoscan.
    I have tried all the request Id's I can find for fuel trims and none of them seem to work on this ecu.
    I get STFT no problem using id 0F, and my lambda sensor is functioning just fine using id 13.
    I have tried (4A, 4B, 4C), (0C, 0D, 0E), (4C, 4D, 4E)
    I either get 0 from them, which I know is perfect, but NOT going to happen!, or I get nothing from them at all!
    I can only assume the UK/Euro '99 flash ecu is different in this respect, but I have not been able to find any other id's to try.
    I could go through them one at a time, but there are a LOT of id's to go through!
    Anyone got any info that may help?
    Many Thanks
    Marty
    Are you getting any of the low/mid front/rear fuel trims registering?
    No fuel trims are registering, apart from the short term.
    Can you zip, and attach a log?
    Sorry, I wouldn't know how to do this.
    Nothing to show really.
    I get no medium or long term trims at all!
    Marty
    This any use?
    Marty
    Hudson, WI
    Are you driving the car around for a while (30 minutes or so)? Low trim is pretty much around idle. Mid fuel trims take a while to update, and you have to be at cruising speed and light load. High fuel trims take even longer to update.
    -Matt
    '15 Corvette Stingray Z51
    Quote Originally Posted by mjannusch View Post
    Yes, I have been doing this.
    Doesn't seem to matter what request id's I use for the fuel trims. Still get 0's.
    Is everyone here using the same id's I have posted above?
    I realise I will not get any front's, as I have only 1 o2 sensor as it's a GTO.
    Many Thanks
    Marty
    www.chromedecu.org verified
    DFW
    Are you using a chrome rom?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
    No. This is a euro 99 flushable ecu.
    Marty
