Sounds pretty fast to me for lifter tick, at least compared to the ticking I had in a different car. I forgot to rev the motor while taking the video... Help me out here guys. Don't mind the dusty dusty motor >.<
That's a lot of noise compared to what I've had on mine, but every car is different... Assuming oil is at required level. Is that on startup or is it already warm? It sounds like there's another (less friendly) noise as well. A slower more metallic noise... It's underneath it all but definitely there.![]()
Yeah, it's sort of a woosh. I'm thinking that's a belt or pulley or something. That main ticking is what has me concerned.
I spent a good bit of the day attempting to check things out and undo some odd things previous owners must have done. I have one cut hard line on the firewall, though I believe it was the clutch booster hardline. Looks like there was a reduction attempted or something, but it wasn't completed properly. I had a bit of smoking happening when I'd idle for a bit and then accelerate, but after checking the pcv valve, it hasn't happened. Oil is full, not old or anything.
I should have taken the time during the cooler months to address a lot of what I'm doing now, though I didn't notice that ticking until the other day.
Woosh? Sounds like there's a separate "chinking" noise underneath the more extravagant ticking. Maybe it's just me...
So is it hot or cold there? Have you tried running through the slow revs method as detailed in the service manual? That always seemed to quiet mine up to an extent whenever it was giving me problems (at least for the drive after I did it). Just curious if that changes anything. If it quiets up after doing so it may give you a little peace of mind and help you figure out where to go next (IE new 3rd gen lifters from NP).
Let us know.
Large screwdriver with your ear to the handle, and the other end to various places on the engine. If it's a lifter this will get youto the exact one. Or spend 10 bucks atHarbor Freight for a stethescope
you can hear lifter tick and the faster lower end noise.
Pull a plug wire off at a time and see if it gets quieter. If it gets quiter on one of the cylinders that rod bearing or wrist pin is out.
classic lifter tick.
Why is your engine idling so high?
-SP
It doesn't idle high, that's why I said it seemed too fast to be lifter tick. Normal idle is around 750-800rpms, but it was idling a bit higher because MY AC WAS ON >.< So to explain...
I figured it out today... and man do I feel like a fucking idiot. I had left my AC on when I got out of the car earlier and didn't realize it. I had cranked the car and was letting it idle to see if it was still going to smoke a bit like it had been when I noticed that fast ticking. Today I was sitting in a drive through and noticed I could hear the sound because of the wall right next to me. I thought "Hmm," reached down and turned off my AC and what do you know, no sound lol.
Regardless, I guess I need to be checking that pulley and compressor out or something. That's a hell of a noise coming from it.
Pull the timing belt cover and check the tensioner. Could be a loose belt slapping. Tensioners have been known to fail.
