Results 1 to 10 of 15
Thread: 2014 Throttle Body Rebuild Service *I'm back*
    TN
    Note: Cores in stock right now- (2) 91/92 ; (2) 93/94 ; (3) 96/97. I can easily make a 96/97 work for a 98/99 by removing one vacuum port.
    Update: I'm currently getting a lot of bad FIAVs. However, I can fix them so they function again. If I have to do this to your throttle body it will be extra $10 because I have to remove the freeze plug and adjust the the inner part of the FIAV. Then reinstall a freeze plug. If you send in your core, and the FIAV needs to be disassembled, I will deduct $10 from the core refund
    I'm back. After evaluating my services, I have really been undercharging for the last couple of years or so. I do more than most, especially when it comes to the exterior. I will clean & paint all the rusty parts that most neglect (dashpot/springs/spring plate). I've rebuilt well over 100 throttle bodies, I have the bills from Cherry Hill, Mil-Spec, and STM to prove it LOL.
    Throttle bodies are completely disassembled, cleaned, exterior bead blasted, re-cleaned to get out any rogue bead material, and put back together. All new bolts are used when I put them back together- Stainless Steel Socket head bolts. Throttle plate has been polished. I also re-coat the spring, spring plate, and dashpot (throttle damper) to prevent rust.
    TPS sensor has been tested, and the TPS sensor will be set. I do not include an ISC anymore.
    I always suggest buying a new ISC if yours is original (aluminum housing). Even though yours may still be good, it's only a matter of time before they go bad. I recommend this particular one: AC99 Idle Air Control Valve IAC | eBay
    If you want an OEM ISC, you can purchase one from here: DSMISC Automotive (New ISC Supplier)
    If your TB is all original, I can guarantee you the shaft seals are shot, as well as the BISS oring. It has nothing to do with the mileage either, because my Spyder had bad shaft seals at 27K miles. If you have done a TT conversion and used your NA TB, you don't even have reinforced seals... you have a rubber collar oring which will not hold boost.
    New parts:
    STM Throttle body shaft seals (2) (same seals as Mil-Spec)
    New throttle plate shaft screws with Loctite Red and peened
    BISS screw, o-ring, and plug
    ISC/IAC o-ring
    ISC bolts
    FIAV o-ring/gasket
    FIAV bolts
    Dashpot bolts
    New Throttle Body gasket- the metal one
    About Mil-Spec Shaft Seals: Mil-Spec Shaft Seals
    Quote Originally Posted by streettunedmotorsports.com
    MIL.SPEC's High Pressure Throttle Shaft Seals. Sold as a pair.
    These seals keep the throttle plate shaft centered and positioned in the throttle body. When they wear out, they can cause leaks, sticking, and jamming of the throttle plate.
    We tested a car on our dyno at STM with OEM leaky seals...
    Replaced those seals with the MIL.SPEC seals...
    Picked up 20 whp and 20 ft pounds! Holy Boost Leak!
    Price is $140 shipped (USA) + your core. International shipping is extra. You can either send your core in first or pay a refundable core charge (see below for core prices). Core must be complete and useable. If you want to keep your sensors, let me know.
    Core charges:
    *91-92: $50 (the one with the dashpot w/ vacuum line)
    *93-95: $60 (the one with the "black hat" dashpot)
    *96-99: $75 (if I have a core in stock)
    Optional Services:
    *Polished: $60
    *Vacuum port delete: $15
    *FIAV Bypass: $15
    *FIAV Blockoff: $15
    I can usually have them shipped same day as payment, or the next day. If you want a polished one, it will be about a week.
    Have any questions feel free to ask.
    I will send you an invoice through PayPal, PM me with your PayPal address, what year TB, and any addition services you would like.
    Standard Rebuild (left) & Polished Rebuild (Right)
    Example of 91-93 Rebuilt
    3000GT/Stealth International Message Center
    Before/After Polish & Rebuild
    (previously sold)
    Before:
    After
    Before
    After
    Before
    After
    VACUUM PORT DELETE- For those who have done the Vacuum Reduction
    This mod is only for those who have done the vacuum reduction! Tired of the vacuum caps still leaking or dry rotting. Well, I have permanent fix for that. I pull out the vacuum ports, drill and tap them, and put in a set screw. Guaranteed never to leak or rot LOL.
    TN
    Correct installation of the throttle body gasket **been getting some people installing them backwards, which will cause a vacuum leak**
    Make sure the little tab is closest to the firewall, or your dashpot. And a properly installed TB gasket should NEVER need any kind of RTV. See picture below.
  3. The Following User Says Thank You to dbest671 For This Useful Post:
  4. #3
    Good to see you back
    Very nice!!
  6. #5
    The following post is a testimonial.
    I was perfectly satisfied with the way my car ran, but as a caution, and also to be sure I'd eliminated every last vestige of a boost leak, I obtained one of April's rebuilds.
    After a quick shave in the the mirror-like throttle-plate, I installed the TB and set the idle to spec.
    I was struck by the unanticipated increase in drivability and smoothness - like butter, as they say.
    Also had a bit of the exhaust rasp go away (intermitent lean condition from tiny intake leak?), so it's a little more pleasing to the ear.
    Big thumbs-up - highly recommended!
  7. #6
    Jun 2014
    Orting
    Just got mine from April. Awesome looking part. I highly recommend buying one as well.
  8. The Following User Says Thank You to notimaginative For This Useful Post:
  9. #7
    April, any plan on offering powder coating as an option?
    TN
    Quote Originally Posted by J-Groove View Post
    Powder coating? I don't do powder coating at all, nor do I know anybody local that does it. If you really wanted I could paint it, I'm pretty good with it and it should not flake off like most I've seen (since I clean and bead blast them).
  11. #9
    Quote Originally Posted by dbest671 View Post
    I'm just thinking so I can have it perfect match my plenum and pipes.
    I'll have to decide which way I want to go. either way will include your rebuilding service though.
    How much do you charge for a new dashpot? Mine is a bit messed up due to a run in with older motormounts and a very close sitting PRM/Carbing strut brace.
    edit: I must have missed it in my first read through.
  12. #10
    Mar 2013
    SL owner since Jan 2010. VR4 owner since Sep 2012
    Riverside, Cali
    April, I've sent you a message on the other site in regards to the rebuild service a couple of days ago. Just a heads up . Hope everything is okay.
    1991 Monza Red VR4- Weekend ride: Tanabe Super Medallion Hyper exhaust, 0.8 bar WGs, Turbosmart MBC (@1 bar), 3SX turbo pre-pipes, Straight pipe, Greddy Type RS BOV, Godspeed FMIC w/ PPE pipes, Stillin DP, HKS duel filters, RPS stage 2 clutch, 3sx SS clutch line, Custom oil catch can w/ braided lines, Krank vents, Ohhnoo's fuel loop, HW fuel pump, PC'd 2G brake swap w/3sx SS lines, Hawk pads, and Stop Tech rotors; Various deletes, PC'd/polished engine stuff, Koyo rad, Greddy coolant cap, DBest custom oil cap, Pit Road M front strut bar, PRM plug cover, PRM tailights, PRM CF Falcon hood and PRM shift knob, Morgan Motorsports splitter, 19x8.5 +27/19x9.5 +24 Volk GT-Cs wrapped Nitto NT555s, 99' bumper conversion, 99' sail panels, 2G side skirts, Retrofitted 5G Celica mirrors, Retro Spec side splitters, RS rain guards, and RS rear window visor, factory GTO light up visors, Custom fit Top Secret style diffuser for 350z, Robo mod w/halos, 3G rear garnish, Momo steering wheel, Tein Street Flex coilovers, 3SX control arms, Apexi turbo timer, Apexi mechanical boost gauge, Zoom Engineering Penta rear view mirror, Veilside navigators foot rest, Pioneer HU
