Preface
Bought this "80,000 mile, good condition" long-block in 2012 after spinning bearings at NG12. Put around a thousand miles on this engine and discovered glitter in the oil before storing the car in Fall 2013. Decided to do my first engine rebuild.
So using this video, I have successfully blueprinted my block and crankshaft:
Here is my dial bore gauge measurement data, data adjusted into actual diameters (adjusting for tool error), calculated out-of-round & calculated cylinder wear from nominal bore diameter:
For reference, if the engine was in the car, Cyl #1 is driver's side front, #2 is driver's side rear. Then "Front-to-Back" is front of the car to back of car cylinder dimension. "Left-to-Right" is drivers side to passenger side of car cylinder dimension.
I went ahead and made the "wear table" a temperature chart for ease of viewing:
Pictures:
Center main bearings took a beating.
Close-up of bearing #1 (Closest to oil pump)
#2 Main Bearing
Another Picture.
I micrometered the crankshaft and all journals are perfect circles with zero taper.
Now what? Don't let me screw this up.
Pistons are expensive.
