Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 142
Thread: Chrome user having major issues and out of ideas!
  1. #41
    You have to understand I am running stock fpr and pretty much the biggest in tank pump you can get and really big injectors and my idle is rock solid.
    I even ran it on 93 setup the same way and had no idle issues.
  2. #42
    So I stopped by auto zone and got the 90 degree elbow I needed and got the fuel pressure gauge hooked up.....tested fpr 51 psi on a cold start......unhooked vacuum line and no change. looks like my fpr is bad? Got the new regulator in and will be installing after dinner.
  3. #43
    Quote Originally Posted by twinspoolin94 View Post
    no, if it doesn't change it just may mean that is as low as it can be. The stock fpr can only flow so much, regardless of the signal sent to it. once you flow enough fuel to get over that hump the signal will be effective.
  4. #44
    I see what your saying, would that not confuse the hell out of the ecu though?
  5. #45
    no not really. you tune the idle and its fine. It just means the injectors act larger at idle.
  6. #46
    I lack color... verified
    Aug 1998
    Can you email me the file currently flashed onto your ECU?
    nonstopmix@gmail.com
  7. #47
    File sent
  8. #48
    Aug 1998
    Got it. Ill check it out tonight when I get home.
  9. #49
    Awesome, thanks bro. I got the my gauge fixed last night and got the new FPR in so tonight ill get base pressure set see how it feels.
  10. #50
    fuel pressure regulator did nothing to help the issue
