Results 1 to 7 of 7
Thread: PTE injector fitment issues
    Easton
    Has anybody ever had an issue with pte injector fitment? As in when I have the rails and injectors seated and tight, the harness connector hits the fuel rail before I can get the it on the injector. The precision one is also about 3/16 of an inch longer.
    Easton
    The injector is too close to the fuel rail when it's all tight and I can't get the connector on.
    there is supposed to be a rubber spacer on top
    Easton
    The ones on the stock injectors right. I tried putting those on too and the rails wouldn't seat all the way down.
    ya you need the little rubber spacers, they are kinda a tight fit but they go in
    with just the spacers and injectors in, the rail should snap on feel sturdy. the bolts just keep it on when you start the car.
    Easton
    Well I put the spacers on and tightened everything down. Got a lot more room but it seemed very tight. Connectors go on now of course. I'll see how it goes when I crank it up.
    Easton
    I got everything together, fired it up with -35 in the maft just to get things started, and my o2s won't cycle. Well they cycle until press the gas pedal then the o2 trim goes straight to 100 and o2v gets stuck at .90+.
