Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Another trans issue
    Secret Lurker Man! verified
    7/10/06 or somethin
    Bend, Oregon
    Another trans issue
    I'll try and keep this as short as possible...Fresh trans rebuild with 3200 miles currently on it. I replaced all synchros and every bearing and seal, all good parts from SCE, and a new Mits slave cylinder, clutch disc, pressure plate, clutch fork, fork pivot ball and T.O.B. I've had the free short throw mod on the shift linkage (drill a hole and mount the cable closer to pivot point, shortening needed travel for gear selection) Never have had any problems with that on any of the three cars I've done that modification to. Car shifts like butter, no issues what-so-ever.
    The other day, exiting the hwy, at a stop light, car was just about blocked out of first, I had to push extremely hard to get it to go into gear. Since I've had the car in my possession I've fought with an almost non existent hydraulic leak from the small little hard line that goes to the slave cylinder, every few months it'd decide to leak more than usual and leave me high n dry. I thought this might be the issue again, though the clutch pedal feel, felt fine.
    So, I nurse it home, fluid level is just below the low mark, so I messed with the leak...it's stopped now, problem solved...nope...I filled and bled the CRAP outta the system, no air and system is good, slave is new and no signs of failure, master hasn't been replaced, but doesn't appear to be leaking, so still good working order as far as I can tell. Car does not want to go into any gear at all while at a stop, engine running. I notice the gear selector is sort of loose sounding, so I ditch the mod and go back to the stock linkage pins. Car goes in to gear (not sure if it's because of the increased throw leverage), but first and reverse are not smooth like before and if you try to go into first, the trans makes a light clunk and if you go from first to reverse, it'll clunk too. No other gear has any issues at all and once moving, trans still feels new and fresh.
    I changed the oil for the first time, oil didn't look bad, some metal on the drain bolt, but that's normal for first oil change after a fresh rebuild. Threw in new MT-85 and no changes.
    I'm paranoid to drive it, in fear that it's gonna go bang again...(don't take yer shit to aamco, they did the previous rebuild which as you can see, cost me a lot to repair, myself) I feel like the linkage or clutch, either hydraulic or mechanical parts are the issue, something not releasing completely or something.
    anyone have any ideas?
    Sorry if this is confusing or hard to follow, just tryin to give as much info as possible...maybe less is more lol
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    Possible clutch drag?
    Sent from my Nexus S
    Oct 2011
    Sundsvall, Sweden
    I was going to say the same, sounds like it could be clutch drag.
    You may need to adjust the pedal free play. It could be off just enough to cause your issues.
    7/10/06 or somethin
    Bend, Oregon
    Yeah, I can't figure it out, it came out of no where. Initially I adjusted everything per jacks trans video or whoever it was, adjusted until you couldn't push the slave, then backed it off until it would give, drove around and re-checked it all. The other day I checked all of this again and it all checks out okay.
    I'm not sure what the deal is, I'd think if my rebuild job was starting to fail, I'd have more noise and difficult shifting through all gears.
    Level hard surface in first rev engine to see if it tries to move. What clutch?
    7/10/06 or somethin
    Bend, Oregon
    Clutch is all new OEM from Mitsubishi, I listed all that was replaced (at work on my phone, pain in the ass to type it out lol)
    Car stays in place. I'm stumped as to why this came outta no where, worried about my rebuild job now, might change the master since it's original anyway and see if that changes anything, also came across a post referencing Jeff's site and an issue with the pedal mounting plate coming loose causing issues, too.
    Yeah I was going there next.
    Sent from the Man Cave!
    *\( ^o^ )/*
    Member
    Chilliwack BC
    You still vacuum assist?
    For sure sounds like the disc is grabbing.
    As a side note, careful when cutting it close with the Jacks method.....I had mine at the fine line for best travel, which didn't leave any freeplay at the top- Many miles later, It somehow changed & stopped bleeding off, & I caught the clutch slipping under pulls. I had not noticed it pump up due to no freeplay- I now take it back from the cutting edge for about 3/4" play. I figured the change was due in part to the vacuum unit misbehaving. There is a critical adjustment between MC/vacuum unit.
    I am not a fan of Jack's method. The easiest way I have found to do it is by actually measuring the free play with a tape measure and adjusting the free play into spec.
