Results 1 to 10 of 28
Thread: Virtual Dyno vs Dynojet at 700hp
    I don't bite
    Southern IN
    BR 2.3 FP Black GSC S2 Toxicfab mani 93 & E85 (VD vs Real dyno comparo inside also) - evolutionm.net
    Quote Originally Posted by tscompusa View Post
    "Notice the low smoothing numbers. If you have to use max smoothing to display a VD graph to make it look smooth then the road is inflating your #'s. it is 100% guaranteed."
    I know VD is becoming more excepted here but there have still been questions because of various high hp inflated numbers. It is vital that your road is flat, level and you can do a pull without wheelspin as VD measures rpms and time. Any jump in rpm will affect the graph. (which is why my atx graphs look crazy until the converter couples)
    If you aren't familiar, Tom (TScomptuned) is a highly regarded and sought after remote tuner geared towards evos and has an impressive list of high hp cars that have been tuned by him.
    August 2010
    Chicago
    Hey...whats up with you posting all this 4 banger stuff...?? We drive V6 cars mang!!
    34XXlbs..
    Nomiez, hahah.
    I don't bite
    Southern IN
    Just trying to help give you validation of what your minivan motor is putting down.
    August 2010
    Chicago
    bahaha...rofl!!!
    I don't bite
    Southern IN
    Just wait til I post a boost graph of my tiny little 4 banger. It will make 9b guys jealous. Well jealous of spool, maybe not power
    Man, twice the torque @ 4k from td04 3.1L vs a T4? 2.3L.
    That dyno is what JBuhrman is looking to replicate in his Evo. Let's hope the earlier torque will help me out!
    I don't bite
    Southern IN
    Unless you both race at 3k I don't see how tq helps you there in a race. An FP Black evo is a serious car and it's also a bolt on turbo. Kinda funny actually that a bolt on 3S and bolt on evo can make similar HP. Crazy that 700awhp is available on each in bolt on fashion. Great time to be a gear head.
    I'm thinking about a bolt on 62mm for my DSM transplant that should be good for 750 on kill. 75lb/min bolt-on! Wtf! (A DSM black is ~60mm and 68lb/min. Not sure if Evo black is the same comp wheel as DSM)
    August 2010
    Chicago
    That I can take your side on...phuck 9b's!!! Hate those little phucking hairdryers...
    Nice! I've certainly looked around and found good examples of VDs matching up with Dynos. If you tune on the same road with the same conditions it's a great tuning tool for sure. My big problem with it is that it's so easy to get bad data out. Like you said, bad road, wheel slip, incorrect weights, incorrect ratios, etc. It's very easy for a user to make a mistake either by accident or on purpose. So instead of trusting the dyno/dyno operator, we have to trust the user.
