Results 1 to 6 of 6
Thread: cant flash with Windows 8
    So my laptop crashed and I am now running windows 8 instead of vista. Ecuflash wont recognize the bin file? is there something I am missing here?
    Oct 2011
    Sundsvall, Sweden
    Please check that you have the most recent version of EcuFlash downloaded from the Tactrix website. The one available for download at the EvoScan website is outdated.
    Ill check it as soon as I get off work. Thanks!
    Apr 2011
    I'm using win 8.1 with the latest ecuflash and evoscan.
    It works. Main thing that prevented me opening the bin file was where I had it located and making sure I had ecuflash user setting set to developer and had the rommetadata file pointing too.
    Sent from my HUAWEI U8950N-51 using Tapatalk
    Proud owner of
    2nd gen Magna TS 1995
    Twin Turbo 6G72 DOHC,
    FWD 5 speed, Jesters Chrome ECU V2,
    Custom 3" Exhaust, Magnaflow High flow Cat & Muffler, Redback resonator,
    CX Racing FMIC kit, EVO 9 BOV, AEM uEGO wideband,
    Turbosmart Gauge, Tactrix 3 port boost solenoid, K&N FIPK
    MSD 8.5 ignition leads, Apexi 3 bar MAP sensor,
    TJ Magna Clutch Master Cyl, 3SX S/S braided fuel line,
    Montero 482 MAF, Aeromotive 340l , 3SX fuel rail loop,
    VAC delete, Fuel pump hotwire and relay bypass
    GTO hubs and rotors, 4 pot calipers
    Tein Flex adjustable coilovers (tuned for +castor)
    Ride build page on FB
    My Vehicle Garage
    Quote Originally Posted by twinspoolin94 View Post
    Glad you came by here!
    If ecuflash says it can't recognize the bin file you do not have the 23862006.xml (or whatever your version is) in the ecuflash rommetadata folder (C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\3000 gt for me, yours may differ)
    The xml version and the bin file version must match to proceed without warnings automatically.
    Thanks for the help guys, I think I got it worked out. I couldn't get it to work outside of x86 as Greg recommends. Checked the options in ecuflash set it to developer level and made sure it was pulling the file from the right place. so far so good! Looks like ill be able to scale my new injectors so I can get the car to 3sx Friday!
