There's definitely a lot of options in the td05 realm...even a billet ball bearing chra...I think there is a lot yet unexplored on our cars.
1993 VR-4
Engine -
IPS catback
Custom Downpipe
Custom FMIC kit
Suspension -
BC Racing coilovers
Solid / Poly busings
It depends on the design and would need testing. That's why companies like FP and DR are still in business selling great performing turbos. They flog their products before selling them so they know what the results are going to be. But in general, yes Billet with extended tip and smaller hub preform better at higher boost than their cast counterparts and produce more hp. They don't magically spool a ton quicker though which is the hype I was talking about. What you could do is downgrade size and increase boost vs cast and then you would make more or same power with quicker spool. That's what the 6262 was doing vs the cast 67.
What turbine wheel are you running? A standard 20g with a td06h4 wheel should be a good match for a 3.7.
Also what is your hp goal? 20gs should take you pretty far as is.
yes, thats what im running I believe. Pic of turbos below. I would like 800, anything above that is icing on the cake!
What about the turbine? The 20g is a td06 turbo so originally came with a td06h wheel that flows very well. These work great on a 2.0 per turbo. When you stick them on a td05 turbine and then on a 1.5l it doesn't work as well. Donnie swapped his 20g to a td06h4 (newer version with better aero) and said the responsiveness and power was improved on his 2.0 vs the td05 wheel.
If you are 3.7, I would guess that the td06h4 wheel would preform better than td05. More flow vs pressure. If you look at the 20g compressor map the efficiency really drops off above 20psi.
I know it will physically fit with current manifolds but my Ac is too important here in the desert lol. I don't like having it rest right on the firewall like that either with the engine moving..if I were going that big I would want to change the turbo location more like dragpro's.
no pics of turbine side :/
any numbers or anything I can look at to tell what I have? These were MHI turbos, so I would assume they came with the td06 turbine wheel...
