Results 11 to 20 of 21
Thread: Gauging interest: Titanium Rods/Nitrided 6G74 crankshafts
    Medford OR
    Quote Originally Posted by BaadVR4 View Post
    Sorry I didn't make that clear. The crankshafts are turned to 6G72 journal size, just like the other stroker cranks out there. Once that's done, custom pistons and rods (rods can be stock 6G72 length) are required. And the block has to be ground for rod/rod bolt clearance.
    So If I buy one of your stroker cranks, I can look forward to spending another $1K or so having the counterweights cut down to fit and heavy metal balanced...
    Did you think Ray was gouging customers by charging what he does just because he was the first to do it? That's not a simple cut the journals to fit conversion.
    One fix at a time verified
    Kansas
    No it's not simple at all. I looked my crank over thoroughly when I got it back. The machine work alone was $950 iirc and the balancing with mallory was another $650 I think. If I ruin this crank I'm going to cry.
    Warner Robins, GA
    Never meant to imply this was a "simple" bolt in. Anytime you put highly modified components into any engine there will be LOTS of things to consider/modify/re-work. Nor do I imply anything whatsoever about Ray's product or pricing. I only meant to offer just what I stated in the post.
    Well, hopefully the Rods come down in a few years...tit rods would be very very nice!
    1996 GTO, Owner since 2003.
    While I'm thinking...you ever looked at selling inverted exhaust valves for our car?
    Warner Robins, GA
    No, can't say I have.
    Just curious about this, wouldn't titanium rods necessitate rebalancing the crank because the reciprocating mass has become significantly lighter? So these things would almost HAVE to be sold as pairs just for it to work right. Or do I have a complete misunderstanding as to how it all works together?
  8. #18
    Warner Robins, GA
    Quote Originally Posted by Lancelot_GT View Post
    Rods are sold as sets of 6. And, yes, the rotating assembly (rods/pistons/crankshaft) must be rebalanced.
  9. #19
    Well yeah, I know they're sold as sets of 6, I meant a set of rods with the rebalanced crank as a pair of parts that go together.
  10. #20
    Warner Robins, GA
    Sorry, I misunderstood your post. As for balancing, the pistons (including rings/pins) are balanced with each other, the rods (including bearings) balanced with each other and then the crankshaft is balanced to the rod/piston assemblies. Balancing a "stroker" assembly is even more difficult because (typically) the counterweights have to be "shaved" to clear the block, which effects the balance. Usually a "stroker" crank will need "Mallory metal" to balance them and it is both very expensive to purchase and difficult (and thus expensive) to install properly.
