Results 1 to 4 of 4
Thread: best way to clean up plastic on bumper
    So I'm trying to figure out the best way to clean up the faded black plastic on my 1st gen. Mainly the middle section of the rear pumper and on the hatch where the class meets the hatch. What prep do you need to do and is there a difference in paints to use
    I just did basic prep and cleaning work, along with primer and some "trim" panel black rattle can. Turned out alright..
    Mar 2014
    "wipe new"
    worked great on my jeep's black plastic.
    Built 2nd week of August 1992 as a 1 of 11 1993 Dodge Stealth R/T twin turbo (6g72 engine with stock TD04-9b turbochargers), pearl white exterior (W29), red leather interior, W5MG1 transaxle. Low mileage, just 68000 miles!
    Current modifications are: VMS racing 10.2mm spark plug wires & NGK BKR6EIX-11 spark plugs gapped down to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, gutted/deleted precatalytic converters, front & rear slotted & drilled brake rotors from ebay, T-bolt stainless clamps, Curt trailer hitch, rear bumper aluminum reinforcement from a 2nd gen car, LED backup & license plate bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, Hurst shifter handle, EGR blockoff plates, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, Koyo radiator with brackets, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Brake Caliper Stiffening Bolts, Pilot WI-HL6A 4656 Head Lamp Conversion Kit
    light sand with a fine grit wet and dry bit of primer and a satin black rattle can and jobs a good un
