This is in regards to a discussion that arose in Oohnoo's SMIC thread, which will be migrated here so as not to crowd his thread.
I'm not disputing that for two cores with the same cubic volume, the one with the larger surface area is going to be superior (I even stated as much when I said that just from sheer surface area a lower quality FMIC core would provide similar performance to a SMIC set up with quality cores.)
What I am saying is that in this particular usage for a core, whether Oohnoo uses 8x8x4.5 cores, 9x9x4.5 cores or 8x8x6 cores, the biggest difference between them is going to be if they can be fit and the cost for our purposes. With proper ducting, the larger volume of the 8x8x6 (which supports a rather substantial 911 CFM each) would be a better choice than a 8x8x4.5 (683 CFM) and potentially than a 9x9x4.5 (for which Bell doesn't offer but a 9x10x4.5 supports 723CFM at $296.) For a front mount intercooler at 18x30x3" (which I believe is actually a bit larger than most for our platform that come in at 24" wide) you support 1080 CFM and it costs $796.
The issue with a 9x9x4.5 is that since Bell doesn't offer one, Oohnoo would have to cut a 9x10x4.5 ( or alternatively a larger 18x10x4.5 at $547) down and then weld it back sealed to do it which would add costs in terms of labor and materials that push the cost of the core (already as much as an 8x8x6") even higher. Throw in that the 9" vertical height would mean you're going to be pushing it to the absolute limit to fit it vertically once the end tanks are welded on (especially if going for 2" piping) and the 9" horizontal width may not fit some year bumpers (and thus removing those owners as potential customers) and it's just not a viable option in this situation.
So long as you don't mind relocating the SMOC and brackets, an 8x8x6" would be the largest core you could conceivably purchase and fit to every model year.
The real world difference between all these different sizes based upon how they will end up being used for the platform will likely be minuscule and just a few horsepower (realistically, how many 3Ss are pushing 900+cfm from each turbo?) We are talking about street driven cars (for the most part) with larger turbos, not F1 cars. At the speeds a F1 car moves, the amount of air that hits those cores is likely more than the amount of air that would hit side mounts AND radiator on our cars at normal speeds.
While the engineering principles are the same, the reality is that very few potential buyers would be willing to front the higher cost to have 9x9x4.5" made and you can't fit a 9x10x4.5 without it sticking out the bottom after adding end tanks or having the 10" be the horizontal width which may not fit some year bumpers. I had it all measured, pictured and written up somewhere with a 97-98 bumper and a splitter (to establish a hard lower limit) and basically ended up with a max of around 13.5" vertical space to work with and I believe a 9.75" width but I can double check these measurements again in a week or two if someone doesn't before me.
If we could fit a 9x10x4.5 core, I'd be all for it, I'm just fairly certain that in this particular instance that it may not fit and if it needs some customizing to fit then it pushes the cost so high as to become unpalatable for most.
I was just disputing that comment you made. Even if the thicker core will work it's not optimal. The thinner core with larger surface area will be more effective, have more airflow through and less likely to heatsoak.
