Ok I am going to put this stuff up for sale and see if any takers, I got lots of bills from wife's 2 brain surgeries that Obama care screwed me over on with super high deductible and need to get them paid. Please no tire kickers, trying to sell as 2 packages with no parting out at this time, it will be an engine package and a turbo kit package. I bought it from here,
Parting My Car out: Big Boy Build
never installed in my car, its the same way as I picked it up from rays.
Motor is a brand new Pampena 3.5 Stroker with all the Options. Has the Upgraded Italo A1 headstuds, New OEM Oil Pump, Water Pump, TBelt, Tensioner etc.. Heads i would argue are the best flowing stock casting 3/s heads out there. They were done by a local guy who does pro mod cars that spent 45 days on them playing with flow etc.. I took my old DR heads i had and on the same bench these flowed more by a good bit. Has custom grind 272 race cams, double springs, retainers, Oversize Valves, Cam Gears, Custom Drivers Side Intake with a billet surge tank and q45 TB. There is so much i am forgetting due to the time i have been building this car.
Everything on this motor is AN Fittings and lines, even the Vaccum lines and Coolant lines. Will come with a Koyo Alum Radiator as well, Custom Catch Can setup with all AN lines and fittings Custom Over flow bottle with catch can and fittings.. So much more i am sure i am forgetting. Everything is powder coated black as well. There is not one vaccum or any line on this build that is a rubber hose. its all hard lined with propper fittings.
10k obo
next turbo kit
Turbo Kit: Custom one off kit. Relocates the Turbos over the Transmission. Every bit of this kit is Vband and heat coated. Turbos are Precision 5857 Dual ball bearing Vband Housing .68 AR, WG are Purple Tial 38's, All the metal used in this kit is top knotch, Kit will come with a 6" Thick ETS Brand New FMIC (core alone was 1400$) With 3" Alum intercoller piping, Tial 50mm Purple BOV, All new couplers and Clamps. 3" Off of each turbo into a 4.5" dynomax bullet downpipe. There will be some removing or moving of some stuff to make this work in your car. It was custom fit into my car. Not having AC.
7.5k obo
Clutchmaster fx850 race clutch special ordered with 2 rigid ceramic disks and a hd pressure plate and steel flywheel, also come with arp flywheel bolts and throwout bearing. Brand new never installed.
1900 obo
300m output shaft from supercar engineering never used just installed.
550.obo
I will list more I have nylon an fuel lines, all phenix an fittings in black, walbro 450 e85 pumps and lots more all brand new I will be adding or can make a better complete drop in package.
Ryan 724-884-6164 can text me.
I can also deliver east and west of Pittsburgh PA I go to NY area frequently.
