excellent suggestion for controlled conditions
Hx52 billet 67mm comp wheel, 350Z headers, Custom 4" exhaust, STM avenger intake mod, Denso 1250's, twin walbro 400's, dual pump/dual feed braided lines from tank to rails,Tial 50mm BOV, Tial 60mm wg, Spec 4+ with hub welded and balanced, Rays Bellhousing brace, flash ECU with openport 2.0 tune, MSD coils with KB boost a spark, MSD race ignition wires, Odyssey PC680, CX racing fmic 1000hp core 28x12x4, ABS delete, EGR delete, AC delete, cruise delete, pansy patrol pulley reduction, Vac reduction
subscribe
Stupid question here I'm sure. But what about doing a vortex muffler style on the exit side of the smic. Creating a vortex or lower pressure that accelerates the air flow. Is that possible. Would that make a difference on efficiency.
When are you taking orders for these again?
Not taking orders till I finish the first set and have Ray test them which I"m sure won't be an issue at all. Once I finish my first set I'll make my jigs for repeatability.
Got to get more seat time welding the end caps and I'll be able to do a double pass in a reasonable amount of time.
Just came back from Rays and was able to semi test fit the one core I made on a 1st Gen to see how they are. Tight on the passenger side but I'm pretty sure I can make it work, drivers side no issues at all, plenty of clearance. If I were to use a shorter 6" core instead of the 8" core there would be no issue at all. Might make this an option as it would use the same end caps I have. 4.5" x 6" x 8.1" - 701cfm
"Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did.w/DBB DR1000's
In theory how much HP can 701cfm manage? I know this is worded horribly because intercoolers do not produce HP, I just didn't know how else to word it...Sorry.
701 cfm is roughly 48 lb/min at ~120°F. So that should be close to 480 HP per intercooler.
Works for me.
I wouldn't spend the added time welding the inside, just run a little hotter- I would set up a plug for the inlet hole & purge them with argon, then they will fuse better on the inside. They look to be about .100"?
