Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 149
Thread: oohnoo - Large SMIC's :)
    Oct 2011
    Sundsvall, Sweden
    The cx racing piping kit has 2" pipes all the way. The tapering is done using simple silicone couplers. The dnp kit however has tapered pipes which makes it harder to adapt for intercoolers with 2" piping.
    I'm using the cx racing pipe kit with a set of gene smic's and apart from the horrible fitment of the intercoolers this works quite well.
    Twin Turbo verified
    Melbourne, Australia
    Interesting. There was a thread about upgrade smics a while ago. Did this spawn from that thread?
    Sent from my GT-I9300 using Tapatalk
    Waiting install
    Build Thread
    Quote Originally Posted by oohnoo View Post
    Piping is always measured in OD. Both the DNP and CX kits the piping is 2" OD but both tapers down to 1 3/4" on the ends to mate up to the oem pipes which are 1 5/8". So actually I think the 1 3/4" piping would work without hurting performance. This way also I'll be able to shorten the end caps a little also....we'll see.
    I have to wait till my car gets back from the shop as Ray did't have a single car there that I can test it on. Either they had the FMIC still on or if it was off the bumper was off also. I did stop by the shop where my care was and did a quick test fit. The mock-up I had was 8.8 wide and fit without any issues but it's going to be tight on the passenger side with the ABS there. Once the car comes back this week I can take my time and make it work.
    Cool, on my car I would not want to remove the ABS, attempting to keep all the original features on the car (only missing active exhaust). I would have to agree with Ray hitting the numbers with stock SMIC's and piping, 1-3/4" would only help.
  4. #24
    Yes you are correct in that the CX Racing setup uses reducing couplers. I'm guessing that you wee able to get them on Gene's 2" piping with to much trouble. Only one I can see giving you a hard time is the one that goes down on the drivers side if you still have the ac dryer. Would it have been better if it was 1 3/4" piping?
    Quote Originally Posted by Unlogic View Post
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    ----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
  5. #25
    Oct 2011
    Sundsvall, Sweden
    It was really tight on the drivers side but not so much due too the thickness of pipes but rather because the pipes on the intercooler were welded on at the wrong f****** angle.
    Sorry for the language but those intercooler fit my car so badly that it took days of modifications to get them properly installed.
  6. #26
    I lack color... verified
    Aug 1998
    I need some kind of ducting setup. Either using the stock plastic ones or some kind of sheet metal. Otherwise, I don't see any serious benefit as the air will tend to want to pass around the IC instead of thru it.
  7. #27
    This!!!!!
  8. #28
    No reason the stock ducting won't work with these.
  9. #29
    yeah I'm pretty sure my oil cooler is doing nothing at the moment, I need to duct it too.
  10. #30
    Aug 1998
    Perfect. Can you make me a set with mounting tabs for the stock ducting? If so, shut up and take my $$!
