A little background info, I am running E85 and the car idles perfect between 14.5 and 14.7. The car cruises slightly richer, around 14.3 to 14.5 The ecu seems to have some small issue dealing with low pulsewidth cruising and my old school style fic 1050s.
I'm sure I could work on the closed loop operational settings and get the window a little tighter, but what I really want is to get the car to cruise and idle at about 15.5:1. Around town the car gets pretty bad mileage, and I think I could squeeze another 10% out of it this way at least. I didn't build this thing to get amazing mileage, but with E85 I really need to squeeze the most out of it as I can when I'm just dailying the car, because the tank is only so big.
I know a couple of you are running with the closed loop feature disabled. It looks like the only way to accomplish this is to completely shut off the closed loop functionality. I know you can change the trim ranges, but I assume that doing so will only cause long term trims to be affected and the short term closed loop function is going to try to pull to 14.7 regardless of what is in the fuel map.
It would be idea if you put higher than 14.7 I the fuel map it would used open loop. I don't believe all of this is documented.
Does anyone have experiences working with this and trying to cruise leaner?
