Yep. Lol.
Yep. Lol.
Green is underappreciated.
3S's look sexy in green!
Something wrong with y'all. Green is the perfect color to paint over!
Went for a nice cruise with my wife with street tires back on and rear coilover damping down 5 clicks. What a fun car![]()
Nitrous stalled up launch on street tires is fun too! Nice controlled spin with a 0-60 of 2.8 sec. Only 30psi so around 600ish hp, so low 10's. A smaller turbo would be better suited for a drive like today, but I'm only a MBC turn away from more POWA whereas something quick spooling would be maxed out to make even this much thru the auto.
