Page 19 of 30 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 295
Thread: Bitching about a 4g in a 3000GT
  1. #181
    Since this is now a weight loss thread, I'll post here.
    Took my scales in Monday to Champion, and tested them with 500lb and 1000lb NIST class F certified weights.
    This is the state stamp showing this weight was legal for certification purposes
    This is what a 1000lb weight shows up as sitting on the scale:
    We tested all 4 pads with both weights, 2 were dead on, 1 was 1 lb light at 1000 and dead on at 500, 1 was 2 lbs light at 1000 and 1lb light at 500, which is well within the "of scale" certification limits for it's 6K lb rating, which means they can be 7 times more accurate than a 80,000lb truck scale @ 3500 lbs.
    tl:dr summery: my scales are confirmed accurate.
  2. #182
    August 2010
    Chicago
    so with this list
    2G Stealth:
    Carbon hood
    lexan roof panel
    gutted interior, power windows still, no speakers or radio or anything but seats, ECU, and a couple aftermarket gauges inside
    solid mounts
    no AC, no heater core, no blower, just firewall
    cruise delete
    sound and heat insulation delete
    ABS delete
    AWS delete
    SRS delete
    had CFDS
    bumper delete
    single shot exhaust, catless
    had coilovers
    lightest 18x9.5 wheels I could find that didn't cost $3K a set
    Conti challenge slicks
    lots and lots of removed brackets and stuff
    big brakes were a wash weight wise, my 355mm just about same weight as stock brakes.
    FMIC which saved a bit of weight
    gutted headlight intake
    splitter gained some weight back
    wingless at the time
    NA brake booster
    vac reduction and deleted everything I could
    no washer tanks
    fog light delete
    fender plastics delete for whats that worth
    fixed back racing seats mounted solid, no sliders
    small things like crank pulley, alternator tensioner delete
    really light steering wheel, lol
    I'm sure I'm forgetting more. Still couldn't break the 3K lb raceweight barrier. Time for more carbon, more lexan, and more holesawing.
    You were able to hit 3056lbs without you and fuel? That's impressive. The little crap really added up on your car..
    34XXlbs..
  3. #183
    Mar 2014
    x
    St. Louis
    oh and BLASPHEMY!....
    Definitely some weight savings though
    Still loving this. Looks like it could have been a factory option or maybe the "base" engine.
    Project LS3S - '94 Stealth
  4. #184
    I don't bite
    Southern IN
    Thanks! Hoped it didn't look to "hacked." I'm also thinking about blacking out the big intercooler pipe, with either flat black or wrinkle black, to make it appear a little more factory.
    The intake will be moved for the holset. In fact, may not have much room for anything more than a big filter straight off the turbo.
  5. #185
    Quote Originally Posted by NOMIEZVR4 View Post
    so with this list
    It's not really that impressive at all.........my car is really a tin can with a seat, it should be a LOT lighter but the 3S has a massive structure. Think of it this way, with a cage me and fuel, my car would be 3610 on the grid. Gutted. Now imagine what it weighs with A/C and all that jazz.
  6. #186
    Mar 2014
    x
    St. Louis
    Can the intake go down and towards the passenger side? With the intercooler pipe where it is, it's hard to go above the trans tunnel. Would be cool if intercooler pipe wrapped around strut tower and you could put intake in stock location. Could also relocate the fuse box and have the intake go there but that's a lot of work for an intake.
  7. #187
    I don't bite
    Southern IN
    I'll try to squeeze it down and put a filter into the stock smic location when I put the holset on. The auto comes more forward than a manual so it limits how big of a pipe I can fit through to the smic location. If I have to, I'll just put a big filter straight on the turbo.
  8. #188
    Oct 2014
    testing to see i can post
  9. #189
    I don't bite
    Southern IN
    Quote Originally Posted by marxsteel View Post
    Yes you can Welcome!
  10. #190
    weighed it today, no driver, unknown fuel:
